A lot of people rave about vintage receivers with higher impedance headphones. So go for it. I think I'm going to dust off my early 80's NAD and give it a listen.Till i buy a dedicated amp... i have an old pioneer vsx 421 that has phones output in its front side. Can it drive the hd6xx? Could not understand it from the manual. Any help is apreciated http://docs.pioneer.eu/Manuals/VSX_421_K_VSX421Ken_manual/
Sennheiser x Massdrop HD6XX Review / Preview - Head-Fi TV
- Thread starter jude
Policar
- Aug 27, 2011
Is this the HD6xx thread or the Stax thread, I'm confused...
Sorry. Just trying to find something that has the best of both worlds. Don't have the money to keep ordering and reselling stuff.
I believe this is still Head-Fi and if it goes too off topic I'm sure a mod will step in. If someone is comparing a different headphone to the 6xx's then I think it is fine to say here.Sorry. Just trying to find something that has the best of both worlds. Don't have the money to keep ordering and reselling stuff.
Policar
- Aug 27, 2011
It's my bad, I'll quit posting here.
Head Fi is freaking out my post are getting screwed up.It's my bad, I'll quit posting here.
You don't have to but if your looking for something the different then that would be the wise choice.It's my bad, I'll quit posting here.
offerbk1
- Feb 18, 2016
Calling it vintage... u make me feel old
But question is if it makes sense. In new amp dacs they write to which typ of hp they r suitable for. Usually it says for hp with up to 100 ohm (or a different number) hd6xx is 300 but i have no idea the output of the vsx 421
MWSVette
Antique would be worse...
rkw
Don't worry about it. The worst thing that can happen is it doesn't have enough output and can't play loud enough — then you need a dedicated amp, but actually it will probably work okay.
offerbk1
- Feb 18, 2016
I m not an expert but i was under the impression that amps r not only about loudness and that it affects the sound quality. M i wrong?
rkw
That is correct, but I don't understand the purpose of your questions. You seem to be afraid to use your receiver because you think it might not be good enough. Well, it is what you are going to use at the moment, so enjoy what you have available now. Yes, you can improve it with a better amp and source, but the upgrade path is never ending.
offerbk1
- Feb 18, 2016
The purpose of the question is to understand if the receiver will be a better amp than what i have in the fiio x1 gen 1 because the receiver is in the garage behind million boxes so if according to its specs no way it will be better then i dont want to go with all the trouble of getting it back into the house ...
MWSVette
Yes, your vintage receiver will drive the HD6XX fine. Whether it is better than your Fiio only you can tell by trying them side by side.
JWolf
- May 3, 2005
Better cannot say. More powerful, yes. The X1 won't have the power to drive the HD 6xx well enough.
Modular
- Jul 9, 2007
Please continue posting here. There will be others with your impressions, and it's good to hear you go through the process.
I've enjoyed reading your thoughts.
