ScottFree
- Apr 1, 2008
The other day I turned up the bass on my IE8 to level 2 and my head exploded.
That is all
I assume it looked like this
That is all
Yeah I didn't think about that, maybe your tape was thinner, less glue on it so it let some air pass. But for me it was exactly the same from closed bass knob to fully opened, once I taped it.
Also there isn't any logic (any logic I can see, I don't say you lie or something) in increasing sub bass with opening port and reducing mid bass by closing it with tape. It's the bass that gets altered all together.
You may have sense of better sub bass because midrange sounds clearer due to less bass, but it really does have less bass overall (both sub and mid).
Bass port is supposed to alter sub bass, but since it's all connected (1 driver, can't separate frequencies) and IE80 already has problems with mid bass it also increases mid bass too. I don't see how opening port a bit can increase sub bass and closing it up with tape reduce mid bass. It's the same port that works the same way.
I don't want to sound like I'm flaming or something, you know what you hear I guess, but it really makes no sense to me at all, which extensive listening I've done has proven to me even tho it didn't need proving.
ok siddhartha talked, "I saw the sign, and it opened up my eyes I saw the sign". (wrong quote?)
Yes, the current IE80's come with that verification system. Amazon is actually an authorized Sennheiser dealer. But when other sellers bring in their stock of products to the Amazon warehouse, chances are, if one of those seller's stock had fakes, it might get mixed with Amazon's stock of the product. To be on the safe side, you could buy from SonicElectronix.com or BHphotovideo.com.
Thanks for the info! I see that the headphones are in stock at BHphotovideo.com and they're the same price as Amazon. I'd prefer to order from Amazon because their customer service is ace if anything goes wrong and I'd get the set this week. If the headphones come with the Sennheiser authentication system, then I don't see any harm in ordering from Amazon as I should be able to verify if they're the real deal or not and return if they are not. Is it still better to order from BHphotovideo.com? If so, I'll bite and wait the extra time for the headphones to come in from them.
It takes 2 - 4 business days to receive your item depending on where you live if you ordered from BHphoto and I believe they are located in NY. These days, most of the retailers have good enough customer support with 30 day return policy and no restocking fee. Regardless, it's hard to beat amazon's customer service.
But you could use Tax as a deciding factor. Amazon collects tax for certain states. And if you are in one of those states, you could save yourself some $$ if you buy from a retailer who doesn't charge tax. And if tax is not a big issue, you could just walk into a nearby BestBuy and get it without the wait (provided they do have it in stock).
Well hell, I was just about to order from BHphoto when I checked this thread this morning, and then just made a quick check on Amazon for the headphones, and lo and behold, they had dropped down to $229 from $308 yesterday! What a great surprise! I placed the order from them as even with tax, it was quite cheaper than BHphoto. I made sure that it is sold by Amazon.com LLC, and it is. I should be able to return if they don't check out via the Sennheiser authentication system. I appreciate your help, and glad I waited a day to order the headphones!
and TBH, if the result had been me being right, I might have been frustrated for wasting my time. but it wasn't a waste of time at all, so I'm disturbingly satisfied that I was wrong
now don't ask me why it behaves like it does, I don't have a clue. maybe the bass setting changes the air volume inside the IEM? maybe something there is a gremlin inside? I really have no idea. but the behavior seems steady so I doubt Senn used gremlins.
I hope apart from self shaming, it can help a little. ^_^
So, basically, in turning the bass screw from 'max' to 'min', you gradually open up an air passage between the front and rear side of the driver, which leads to acoustic short-circuiting and a drop in bass level. And because of that, the tape mod's effect is only loosely related to the bass dial, since it only seals off the rear chamber and has next to no influence on the internal airflow between the front and rear side of the driver.
