Just read a nice review of 800s by @joshnor713 on his website. He mentions they only ship with Comply. My serial is 007xx and I could swear they also had silicone as I am using the same size on both my 800 and 800s.
Sennheiser IE800 IEM's
- Thread starter PhilW
- Tags
- sennheiser-ie800
joshnor713
Didn't say they ship with only Comply. Said the Comply replaced the oval silicone tips. The circular silicone are still there. But you made me realize I should specifically say that for folks not familiar with the original model.
Thanks for reading BTW
- Nov 28, 2016
I find the silicon tips give me the best seal. The 800(s) really is a smooth presentation with no boosts in the bass or treble to my ears. Just give them a few hours to let the brain adjust. I also have Legend X and when I first put on the 800(s) in the coffee shop I think they are a bit bass shy but soon they melt away.
I prefer the T200 series Comply foams. Interestingly they fit the ie800 perfectly and are cheaper than the model specific Comply!
ruthieandjohn
Stumbling towards enlightenment
(Formerly known as kayandjohn.)
... and the model-specific Comply tips fall off in your ear just as much as the original tips!
I don't seem to have that problem with the stock silicon tips. I will try the Comply this weekend. I find the Comply deaden some of the highs.... and the model-specific Comply tips fall off in your ear just as much as the original tips!
huggy020
- Apr 16, 2010
Anybody know how to separate the driver from the case for rewiring. One of the channels not working. Something similar to the photo
Vesperaudio
Member of the Trade: Vesperaudio
- Nov 30, 2012
Couple years of experimenting and 10-20 dead drivers and you will cope with this)
IE800 is one of industry's hardest earphones in terms of recabling.
BTW, there are fake earphones on your photo.
huggy020
- Apr 16, 2010
Thanks for the reply. You sound like you are offering a service lolCouple years of experimenting and 10-20 dead drivers and you will cope with this)
Vesperaudio
- Nov 30, 2012
Exactly. Nevertheless, you will definately waste your time and efforts. There are many earphones that can be recabled without pro experience but ie800 are not one of them.
huggy020
- Apr 16, 2010
I'm still going to give it a shot. Once something can be done by one person means another person could repeat. I'm not a novice at this, just trying to find out if anybody has done it here. The photo is not mine... just to further explain my point. The driver is held by glue. There is nothing like a a glue that cannot be "unglued"... just different degrees of difficulty. RegardsExactly. Nevertheless, you will definately waste your time and efforts. There are many earphones that can be recabled without pro experience but ie800 are not one of them.
Vesperaudio
- Nov 30, 2012
Wise and beautiful words. The problem is - counductive threads that are ~0,005 mm in diameter are in this glue between enclosure and driver outer shell. Glue (rubber compound to be exact) is very strong. You are going to remove this glue without damaging threads. And there are many other problems even if you secceed with this one. So of course anyone can play guitar, but if you have only one try to play some complex tune on the instrument you've never seen before chances are low. Though not zero of course.
huggy020
- Apr 16, 2010
Thanks , will let you know laterWise and beautiful words. The problem is - counductive threads that are ~0,005 mm in diameter are in this glue between enclosure and driver outer shell. Glue (rubber compound to be exact) is very strong. You are going to remove this glue without damaging threads. And there are many other problems even if you secceed with this one. So of course anyone can play guitar, but if you have only one try to play some complex tune on the instrument you've never seen before chances are low. Though not zero of course.
huggy020
- Apr 16, 2010
huggy020
- Apr 16, 2010
Deleted
Cheesedoodle
- Jul 24, 2015
You, my friend, are an intrepid soul.
Ok ,managed to get the driver out safely. Heat gun and aluminium foil wrapped around the plastic parts. Wasnt careful with the foil around the strain relief so l lost that. Will have to source that somewhere.
