Sennheiser IE800 IEM's
post-15405954
Post #7,681 of 7,687
huggy020
Please post...
one more thing, inner mesh on mine came off. I was checking AliExpress, do you think these will be an replacement
https://www.aliexpress.com/item/32800734441.html?spm=a2g0o.cart.0.0.dd003c00R37XK7&mp=1
The space between the wires looks a bit tiny. I earlier did one for one of the earphones from the mesh in a smoking pipe(check Amazon] . It turned out to be more work than anticipated. I used the tool for cutting holes in a leather belt. Whatever happens you have to protect the driver from earwax etc.
post-15406197
Post #7,682 of 7,687
Vesperaudio
Member of the Trade: Vesperaudio
Please post photo of this(nozzle). Genuie ie800 mesh can hardly came off without being damaged mechanically, it is fixed thermally, not simply inserted. Just to make sure your earphones are genuine. Or do you mean mesh on the eartip?
post-15406270
Post #7,683 of 7,687
musicinmymind
I got these directly from Sennheiser usa around 4 years back on thanks give sale for 550$, It is not be fake for sure.
Will post pics once I am back from work.
post-15406772
Post #7,684 of 7,687
musicinmymind
post-15406774
Post #7,685 of 7,687
musicinmymind
I am liking SQ without mesh, more aggressive and fun
Mesh came off on only one side, to restore balance i pulled other one off. I am sure it is glue
post-15408207
Post #7,686 of 7,687
Vesperaudio
Your earphones are genuine.
Yep, I found one nozzle with glued mesh, while other have deeper groove with thermally fixed mesh, probably different revisions. Anyway, there are two main differences between stock and chinese meshes - density (as mentioned by huggy020) and form - stock has beer cap shape, chinese are flat. Chinese have double-sided adhessive and will also work. 4,3 mm. is stock diameter, but I suppose 4 is the closest available, it'll fit but will significantly change the sound due to it's density. Imo, it is better to apply tiny peace of some rarefied napkin under the eartip mesh, just to protect driver from any specks. You can also try to extract meshes from pair of stock eartips that you do not use. Or just use as is, keeping it clean)
post-15467402
Post #7,687 of 7,687
rafamaniac
Porto
Porto
I really want to buy the campfire atlas after having the is800 but this iems are so expansive in general that my wallet says to me “maybe on another universe pal” it’s sad
