Sennheiser IE800 IEM's
post-10807314
Post #2,221 of 7,791
Kunlun
The jhaudio case is the best I've seen, other than an otter box or pelican case with padding inside.
Okay, ie800 questions for everybody who owns one!
1. Is there a mod to thicken the treble? A filter, something, anything to make the treble less thin? (see also question #2).
2. Have people been playing with the two vents? One vent (the top one if the iem is cable down) effects the bass, have people been blocking or limiting that (tape with a tiny hole in it is a common mod for dynamic drivers, c.f. the sony xba-h3)
The other vent (the bottom one, if the iem is cable down) is the one that equalizes pressure. This one maybe is related to treble in terms of reducing insertion resonance peaks?
What do you find when you limit each vent in turn? Or when you block one and then the other off entirely?
Thanks!
I had these for two months. The thin treble got to me, but I keep thinking I should try them again.
post-10807342
Post #2,222 of 7,791
joey99
   short and noisy cable +1. Fortunately I do not move while listening to music. The case is dumb+1. I bought $1 hard cases for it. And I found cases for IE800 is still better than cases for K3003. 846 cases is the best.
The 846 definitely has the best case that's actually useful and protective .. and looks nice. I tend to use my IE800 at my desk and in bed so I really don't have issues with cable noise either ... I only went out with them a few times just to try but found the IM70 and now the 846 just much less fiddly to take out and these don't need a shirt clip and no fiddling with fit at all. Where as the Ie800, I have to have the right length on top of the shirt clip and that big connector is just so in the wrong place it's not funny ... it can be overcome with adjustment of where you clip the thing but it's just not well designed. Seems like they just used random length without getting people to try it. It's y-spitter is too short in the first place and then the connector is too big and heavy which sometimes drag your iems out ... then the cable after that is just too short too by a little.
After a while these negatives are not really noticeable anymore ... they are comfortable and I enjoy music out of them very much.
post-10807347
Post #2,223 of 7,791
joey99
at first I found the IE800 a bit thin everywhere but I now use the bigger tips to get a better seal and it has really good bass and makes it overall less thin.
post-10807509
Post #2,224 of 7,791
james444
Thanks!
Adding a thin layer of damping (alcoholic swab, microfiber cloth) mitigates the problem somewhat.
Jm2c, I'd rather get a few pairs of Zero Audio Tenores and mod those than try to mod the IE800. The former are close enough in sound quality, but much cheaper, more ergonomic and pretty easy to mod.
post-10807550
Post #2,225 of 7,791
3nenbgumi
Not trying to get sidetracked here, but I have recently brieftly demo'ed the Tenore and while it sounded really good for the price, it didn't sound like a giant killer to me. I found it to be, well, a bit too flat sounding and perhaps lackluster for a lack of a better word. In fact, I much preferred the Ostry KC06A to it. Or perhaps I've been spoiled too much lately by the JH13's PraT so that anything with a bit more neutrality than it would come of as being a bit bland to me.
Just my 423.70 dong of course
post-10807632
Post #2,226 of 7,791
james444
^ I was just talking about the IE800 and Tenores. Tbh, I wouldn't get either of them if I were looking for PRaT.
post-10807646
Post #2,227 of 7,791
3nenbgumi
Oh sorry I did not mean PRaT specifically. More like a wow factor if you will. Something that the 800's possess but the Tenore doesn't. Or maybe my ears aren't meant for neutral gear :p
post-10807671
Post #2,228 of 7,791
james444
Thing is, wow factor is very very subjective. Some here will wildely disagree with your IE800 vs. Tenore wow factor assessment.
post-10807752
Post #2,229 of 7,791
ApaucalyptiK
Found out that Jabra Rox tips are compatible with the IE800, even with deep and tight insertion they don't fall of and stay stuck in the ear (unlike Comply T500 and other stuff i tried), so it can be a real alternative.
post-10807784
Post #2,230 of 7,791
3nenbgumi
Fair enough. Let us agree to disagree, though I fully understand that for some folks, the Tenore's wow factor might just be the fact that it has no wow factor at all. My 2 cents have always been there, you know :)
post-10807801
Post #2,231 of 7,791
dsincere
This is nice to know for those with fit issues ...and the Comply T500 does not come off nor get stuck in ear ...if one follows the mod I posted sometime ago because it uses the existing hub and locking mechanism of the 800s.....☺
post-10808709
Post #2,232 of 7,791
coco8579
Does anyone know how many digits for the serial no,  the current batches have?  The retailer who where I sent mine back said that they have 1 unit with 123xxxxxxx digits (10 digits). Does anyone know if thats part of the new batch? Thanks
post-10808844
Post #2,233 of 7,791
daseinpdx
I think the 10 digit number refers to the ID number on the box.  There is also a 5 digit s/n on the leather case.   The ID number is on the authentication decal on the box.   I think the purpose of that is to make it easier to distinguish between authentic and counterfeit products.   When i returned mine to Sennheiser directly, they accepted my 5 digit serial number.   The new one i got back also had a 10 digit ID on the box and 5 digit S/N in the leather case.
post-10809115
Post #2,234 of 7,791
chawya22
The last 5 digits of the 10 digit id number on the box is your serial number. I just went through this with my recently replaced ie800. If you check your case and check the box, they should match.
post-10810760
Post #2,235 of 7,791
VictorRomeo
So I collected my ie800s today from my local HiFi store - yep, I bought bricks and mortar!  Anyhow, I'm having a nightmare of a time with the supplied tips for isolation.  I'm getting zero bass from anything other than the medium tips supplied and even then it's extremely weak. For reference, my Klipsch x10is have a much deeper bass line - but then they insert much deeper so I get a great seal.  I'm not sure where this will end up but I'm beginning to get bothered by the fact that none of my stock of tips from Shure, UE, Klipsch, Sony will get me out of a hole here....
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
