ericp10
Sits up all night comparing IEMs.
- Nov 14, 2009
Would anyone be able to sum up the differences between the Miles Davis' and the IE8's in terms of sound signature? At the moment it's between them two, they're around the same price (if the MD's are genuine) although the MD's have a higher RRP but that doesn't mean they're better by the look of it. Any comments would be appreciated.
Here are the photos from the seller. I'm not sure how to spot fakes, I heard the gold part on the back of the earphone is plastic instead of metal on the fakes but I cant check that from a photo. Anaxilus, if you could compare them to yours that would be appreciated.
Mids are much more forward with the Miles Davis and better highs too. The soundstage is wider with the IE8. I liked the bass better with the MD, but both have great deep bass. The IE8, however, has more of a mid-bass hump. It's hard to tell if these are fake or not with the photo, but there is a case missing (should be three cases). One case should be a hard case that looks like a replica of Miles' trumpet case.
