muscular
- Jul 3, 2009
The IE8s have long been replaced by the IE80.
Design and sonic wise, they're most similar than different.
After IE80 was released.
Same guy before the IE80, describing the IE8 in this very thread. Someone steal your password?
Yes you have the ability to EQ your IEMs or headphones to your preference but that will also very from genre to genre and to be honest I rather not be stressing out over constantly EQ an IEM.
There's no stress Lee, you simply set the EQ up and press play.You're exasperating yourself over thinking.At most I have two presets, one for energy and another balanced, switching between depending on mood, these does not need changing every genre, not at all.... You can't really say that a DAP without any EQing is going to be spot on perfect with every genre and IEM pairing because I can't see how that would work. There's going to be differences, EQing's all about finding that sweet spot not moulding the IEM into another shape, very fine adjustments, for example me? I like to tweak the treble a touch regardless of IEM response.
I think in the perfect world obviously pairing without EQ is the preferred audiophile way, though lets face it, that can become very expensive changing an IEM just because you're missing that tiny little bit of bass or mids. Then you have the problem once changing that IEM of altering the entire signature. So the simple answer is to EQ these areas's. Once you have a player that deals with EQ respectively the changes cost you nothing and in most cases very rewarding.
lol not for me generally. While an EQ may work for a certain track or genre it won't necessarily do the trick for the rest and will sound off to my ears. Just another reason why I generally hate using EQ. Most of the time I don't bother and if I can get that full satisfactions and feel the sound doesn't need EQ, then I am truly enjoying my music . Yes the EQ did help with the IE8 but I was not happy to have to be using it to fix a flaw that should have been noticed before even releasing the product, especially at the $300+ price point, it was a slap in the face to me. If the IE80 didn't fix that issue for me I would have moved on a long time ago. But the overall sound signature was what I was looking for, so I stuck it out and reaped the benefits .
Haha. I can understand how rewarding it may be having a pairing spot on to ones preferences. Such would feel like a mission accomplished also very satisfying .I can see both sides of this story as yourself. Though for me it also seems quite a costly endurance, I think we've spoken previously how I wouldn't like that feeling of being locked out of an EQ.
You should check out Cowon players one day Lee. I think you'd find them very enjoyable.lol
For an IEM is really does have a large sound stage. Of course your full size headphones should have an even larger sound stage. Take into consideration how much larger your full size cans are and try to put it all into perspective. Also your sources will play a big roll on the overall size of the sound stage.
I did and wasn't impressed compared to devices on hand at the time. I had my iphone4 and an SFLO2 at that time and didn't think it was an improvement over the iphone4 (with eQU) and not even in competition with the SFLO2 (sound quality wise). Not sure if you've seen some of my nasty comments regarding the SFLO2 as I'm not the biggest fan of that unit either. So in comparison to the gear I have now I can confidently say the Cowon just doesn't compare. Different tiers. Its a good product though but had nothing that I already didn't have or have in spades . While the Sflo2 may be a big jump over the iphone4 and Cowons, its flaws (and defects) were just too much for me to deal with and I've long since moved from that unit.
I certainly agree that the source is important. I am constantly amazed at how the source affects the sound.
I suppose for me the IE8 has less of a 3-D effect. It's more side to side and I can appreciate how some smaller detail seem out on the edges. But I'm use to the background singers (on some songs) being out beyond my ears (with the 535) instead of within the head-space as with the IE8.
I already knew your thoughts on Cowons and SFLO2.Anyway, enjoy your IE8 guy's, sorry to drift away from the subject.I was pulling your leg
I think those tips are really making it where you aren't getting those out of head experiences. For what its worth, the IE8 gave me the most out of head experiences out of all the IEMs I've had to date. Like I'd be out and about and turn around thinking something happened behind me, to my side, up in the air, lol. Maybe try the mod listed on the IE80 thread (cover up the adjustable vents with a piece of tape) and use a pair of tips that wont constrict the sound like the triple flanges. I find the Sony Hybrid IEMs to do the same thing, even on their EX series (makes the sound stage unnaturally narrow (thin) and it lacks that 3D sound that I like. At least on the IE80 the mod really brings the mids forward (in your face), the treble also is very detailed this way and has lots of texture and presence. Mid bass is tamed big time, and emphasis is strictly on sub bass without the mid bass interfering. Sound stage took a slight hit but not much at all IMO. What you get is a much more precise sound stage, imaging is superb, and speed is spot on. Also the IE80 will respond more to what is called for in the actual track. If the sound stage is large in the track, it will be large on the IE80. Same with bass. If there is a lot of it, there will be a lot.
How dare you! lol. Just wait til you try out the Rocoo BA. Gonna open up your eyes .
Well, I gave the (tape over the vents) thing a try and switched back to the regular tips. The bass was a little shy and the sound-stage was the same (at least for the few seconds I managed to get a painful- but good- seal). The IE8's nozzle is too short (and the housing too fat) with the standard tips to get into my (oddly small yet) deep ears. Before getting the proper seal, the sound was sibilant and veil (which was as I remembered 3 years ago). Had I listened longer (with the bad seal), I probably would have noticed the bloat again. I took the tape off and tried again with the original tips and yeah, it was just an inadequate seal. The Monster tips only served to provide a decent seal for me (apparently with no particular sound shaping).
I noticed that my newly acquired Shure SE530 (thanks to a head-fier's price alert) has noticeably less sound-stage than my 535. The 530 has a slight mid-bass bump. I used the exact same triple-flanges taken from the 535 (same player, same song, same everything). The IE8 and IE80 may be different (in regards to sound-stage) as well.
Again, I do notice the sounds that could be interpreted as distant (giving the sense of sound-stage width) but without more depth, my brain is not having it (during typical songs). There are some songs (recorded in such a way) that even my old Sony MDR-v100 (from the 90s) has me looking around.
So it seems you have large ear canals? Did you consider trying the large single flange tips from JVC. They are dirt cheap on ebay.com. The seller sells pairs of 6 and 8 for about $5.00 including shipping. Very well worth the price. The IE80s also sit deep in my ears and only this tip and the large single flange V-moda tips give me any form of seal. Even had issues with the very large double and triple flanges. Don't offer me any sort of seal at all. I'm curious though are your IE8s genuine? Did you get them from a genuine dealer? So many fakes out there it is pathetic.
http://www.ebay.com/itm/8-x-Replacement-Ear-Phone-Ear-Bud-Headphone-Gel-Tips-Various-Colours-Large-/230844350654?pt=LH_DefaultDomain_3&var=&hash=item7b6aeb9786
