obentou
- Nov 26, 2006
If I remember correctly, the W3's had a greater upper bass; as for bass extension, I find the IE8 wins in that department. The IE8's bass can get a little too deep for my tastes, so that is why I am considering the switch.
I used the yellow foamies and a medium comply tip to test the W3's. Sorry for my crappy explanation, but hopefully I can get in touch with Pianist again to do a swap sometime so I can do relaxed listening at home.
Perhaps HA can offer a much better opinion from his experience with all sorts of audio equipment, after his IE8's burn in. I am sure it will be a positive one.
Originally Posted by Edward Ng /img/forum/go_quote.gif You find the Westone 3 to have stronger bass than the IE8...which tips did you test the Westone 3 with? Also, do you recall if the greater bass on the Westone 3 was in the upper bass or was it in the lower bass? Any difference in bass extension in your experience? Sorry if I'm asking things you can't answer, I won't hold it against you if you don't know. After all, that was a much too brief listening session you had. -Ed |
