Bass question...
I JUST received my Sennheiser HDVD 800 DAC/amp, as well as the HD 800 headphones. It sounds GREAT on .wav files played via USB port into the HDVD DAC, then amp, then HD 800 headphones.
Colorware-coordinated Sennheiser HD 800, HDVD 800, and FIAT Abarth for the best in on-the-road headphone listening!
Then I tried my bass test track, which happens to be an AAC (i.e. "iTunes" file at 256 kb/sec VBR) file. Test track is "Throwback" by B.o.B. on album "Underground Luxury," where starting in the third verse, strong bass below 50 Hz (i.e. in the lowest octave of the piano) is played.
The bass sounded CLIPPED and SATURATED and DISTORTED! It sounds similarly distorted on another headphone (Sennheiser HD 598) through the HDVD 800 amp instead of the HD 800 headphones. So it was not the HD 800s.
I tried another song, Massive Attack's "Angel," coded in the same way.
Sub bass was again DISTORTED!
Neither are the least bit distorted when played on my iPod in the same format.
I then tried iPod Lighening connector digital output to Sony PHA-1 DAC and amp to HD 800 headphones (PHA-1 actually decodes the digital stream from the iPod, not recreating an analog line out from a DAC in the connector as is sometimes the case). Again, NO distortion.
I then went to the "Heartbeat" track of Chesky's Ultimate Headphone Demonstration Disk (pulses at first 50 Hz, then 40 Hz, then 30 Hz, then 20 Hz). No problem, no distortion.
I then managed to find a lossless version of "Throwback" (Chinese site!). NO BASS DISTORTION!
So...
1) Is it a characteristic of iTunes compression to distort very low bass, but you must have a powerful amp for it to be maintained at its original volume for the distortion to appear?
2) Can you suggest a lossless song with strong subbass and where to find it so I can try that?
Thanks!
