thinker
- Oct 23, 2009
HDVD-800 Ok. with Mavericks?
I do not know the topology of the amps.
But if I input SE I do get bal out. I did the test a few ways. One way was with the ps audio DS in bal out and SE out. And both SE and BAL out and I feel there is no real change other then the volume.
Al
Using the oppo. Keep,in mind read the directions to des able the internal dac. Otherwise even though you are using the coax out it still goes through the dac inside the oppo. Also the dac inside the hdvd800 is ok but needs a AP1/PP to sound it's best.
BTW, I do not think it is possible for you to compare how this amp perform on the input side.
Since "xlr in" can only produce "xlr out", and "rca in" can only produce the "single ended out".
Therefore, I do not think you can just used one output to evaluate both inputs at the same time. If the output is bounded with the input, then, it is a very high chance that they are using different topology to amp the signal from these inputs.
I am very curious how you arrived such conclusion on the inputs.
Cheers
I've just got mine (HDVA600) yesterday and even though I'm still running it with SE-out and RCA-in, it sounds exceptional already. I hope it would get even better after my balanced cable arrive..
There is no two ways about it, The XLR capabilities of the amp are superior to the SE capabilities. Once you hear the XLR output you will likely never go back.
The full balanced capabilities tends to provide better dynamics and cleaner separation of sounds. Instruments tend to sound more distinct. Again, the differences depend on your source material, input that you are using, and your hearing sensitivities.
Rest assured that the XLR will NEVER sound worst than the SE
-Jeff
For noobies like me that have both an HD800 headphone and an HDVD 800 amp on their way to me, what is the tutorial on changing from SE to XLR? Is it getting the ~$350 cable that Sennheiser provides? Anything else, given the 800- amp AND headphones? Thanks!
