chimney189
- Aug 31, 2016
Sometimes it's the bass of the 800S that impresses me the most.
Very detailed and textured.
Yeah, my HD800 have strobe light that automatically turn on when playing Abba.
You might have got jipped.
If your having trouble with the HD-800S staying put, just wrap a washcloth around the headband. For something more secure, try one of those shoulder belt pad things from the local auto parts store. And you should stop worrying so much about the steel mesh getting damaged. I've had the HD-800 for seven years and the steel mesh is still like new.Now you tell me.
And nobody told me about the loose fit problem What.
Aka, move yo head and yo cans be dead by falling off and hitting the flo
< will use elastic bands to keep things tight, wallet will not fit.
< on the down lo talking schiit.
Lay down on the flo
Lay down on the flo
Am in a rage
So if we gotta do this let me no,
Thats wut I came fo
Thats wut I came fo
Veryyyy goodddd record for your hd800s as "the way it is"
Tidal.
I do like my 800s
Only thing that I could really pick on is the less than tight fit.
Its cool, I keeping them and have a few ideas, one of them is in the posts above, tieing something around them and see if they tighten up, also bought some dekoni elite sheep pads, they seem chunkier and may possibly fix it for me ? < just happy jim didnt fix it for me instead.
Jimmy doesnt do headphones.
Only K...
Frame of hd800s need to be stronger for supporting dynamic load.
Some tracks sound heavenly while holding tigh 2 cups.
Change ear cup can makes changing of rigidity and distance ear to driver. It change the sound.
800/s need a strong support for vibrating of driver. I sometimes hold it several ways and feel it disappear from my ear. Just sound remain like in real enviroiment
Read somewhear that its headband use damping meterial to kill vibrating and infacts it vibrate less than hd650. But 800s use a bigger driver and "more open" air so need more hard and solid base
I've heard nothing but bad reports about the sound of the Dakoni pads.Just got my Dekoni Elite sheep pads.
Sennheiser so easy to get off.
Dekoni easy to put on
Dekoni is a nightmare to come off
Sennheiser nightmare to put back on.
£70 wasted
However Dakoni really nice and comfy, but music sounds like it was coming from a walkman in 1981, on a loose C60 < before 90 and 120 minutes were invented.
Openness gone, BB King left the room, had to fight sennheiser to get him back.
I think I will probably cut the mesh on the bottom of the dakonis, it may help lose some of the muffle that they created ?
I do like and love the feel, but they do detract from huge stage the 800s have, will try the fluffy one and hybrid one to see if they are just as bad.
deep in the sheepTrust me, I have schiit hearing and I noticed it right away.
I would love official sennheiser ones that are leather and thicker height wise, I hate this fluffy schiit as default pads, as they mank up quickly, sweat etc. Would even prefer pleather over felt pad.
The Dekoni’s are nice, no getting away from it, but they seem to not only be thicker height wise, but also have a thicker width.
If they could keep same width as the senn ones, and, if they did not have that womens tights looking material at the bottom of the donut, they might actually be able to keep the same huge stage whilst making the 800S so much more comfier and less prone to moving.
Cans moving happens to me, not bad moving, but I wont be air guitaring it up with them on.
Conclusion.
Elite sheep are nice looking, but failed to comply with the contract sonically and need to be thinner width wise and have no material at the bottom. I am positive ( not really ) that the material on the bottom is a major factor in the equation and which I think dampens down the sound.
I just dont want to cut up £70 the same day I got it.
