Here are some of my initial impressions of the HD660S at around the 2 hour mark of listening to them:
Comfort - The overall comfort in my opinion is great. The pads are firm, but I reckon they will soften up after a little more use. Weight wise these things are pretty much as light as it gets so no worries there. The only gripe I have is that the clamp is a little much straight out of the box, but you can fix that through some careful stretching of the headphones.
Nit Picks - I'm not a big fan of the stock cables, wish it came with a balanced 4 pin xlr instead of the 4.4mm balanced connector. The cables seem as if they are almost an after thought, not the greatest quality and they are bound together tightly with a twist tie so they are all twisted up and messy out of the box. (Again this is me being picky) Lastly, the top layer of foam in my box doesn't fit properly so it won't sit flat.
Treble - This is probably my favorite part of these headphones. All the higher frequency shimmer and ting exactly how I like them to shimmer and ting, the HD660S almost feel like a baby HD800S from my memory in this regard.
Mids - Not really gonna touch this yet...still experimenting...
Bass - I am a little bit of a basshead so naturally an open back pair of headphones will often times be a little bass light. So with that being said the HD660S do seem a little bit light on bass
quantity. Now as far as bass
quality goes these really remind me of the DT1990 Pro. Every single low note I throw at them digs deep and stays detailed as I would expect from a $500 set of headphones, these things dig
low!!! As far as punchiness goes I think the HD660S check the mark there too, not overwhelming, but not too little for my taste.
Misc Sound - The background of the tracks feel about as dark as they can get in the HD660S. As far as sound stage goes these have an adequate width too them, nothing like the HD800S, but a healthy amount. Same goes with imaging, the HD660S are pretty much spot on.
I didn't hearing any sort of a veil with these headphones, and this is coming from someone who can easily listen to some rather bright Beyerdynamics, which is fantastic.
If I had to sum the HD660S up in one sentence it would be "The most right headphone for $500."
- Hope this helps!
*Remember these are my impressions, my ears are far from perfect, and my opinions differ from others.*
