jim580
- Mar 14, 2006
Wonderful review! One of the best I've read.
Bravo!
And Thanks.
Jim
Bravo!
And Thanks.
Jim
Originally Posted by Mercuttio I've sort of personally made a decision about the "veil." I really only hear it when I switch directly from a bright can (the SA5K in particular) over to the Senn. The thing is, you just can't do that. The balance of the HD650 is TOTALLY different. It's merely providing you a different view of the treble regions. You have to step away from the presentation of the other headphone, and approach the 650 with new ears. |
Originally Posted by vpivinylspinner I noticed the same exact thing. If I go from the SA-5000 to the HD-650 I feel like I have lost alot of the shine and it seems boring in comparison. When I switch from the K-701 to the HD-650, I certainly get a different presentation and a little less lively sound but the Sennheiser sounds very good in comparison as it does with all of my other headphones. I think it just takes some time to get used to drastic changes. |
Originally Posted by slinger1182 Hehe, I just took out the foams from my HD580s and I love the new sound. They sound quite a bit clearer and aggressive. I put that foam inside the grey grills (made it a semi-closed can. That seems to have made the bass tad tighter and faster. I have a question though. The driver is now unprotected. How could I clean it if it gathers dust or do I put in a thinner cloth like the guy on the previous page suggested? I really don't want to do that because I love the new clarity. It's just perfect for me (not dark but not harsh either) and don't want to do anything to lessen it even a little bit. |
Originally Posted by slinger1182 Hmm, they are definitely quite a bit more clear and aggressive than with the foams on. I really do love this sound. But I might just put em back to keep the drivers from getting dirty. |
Originally Posted by practitioner It's spot on in describing the HD650 |
Originally Posted by ktm Try cutting out a piece of black pantyhose. It will protect the driver while allowing the sound to come through. The best procedure was to rough cut the pantyhose, stretching it to fit over the driver while re-installing the earpads. Then tug gently on the edges while trimming with scissors. The hose will then snap back under the earpad. It may take more than one time to get it right. I didn't like this sound and put the foam back in. Woodies give me the sound I was looking for from the 650's. |
Originally Posted by bill99hawk I tried removing the foam inserts, and I didn't like the sound as much. It was more open sounding, but the full bodied sound was gone. |
