2100
- Mar 24, 2005
Yup, my thoughts on the phones are not far off too. I think a small problem is that they are priced too expensive in the U.S, so it's not that good value for money comparatively.
Originally Posted by aerius If frequency response could explain tone, life would be a lot simpler. If I knew why some headphones have good tone and others don't, and could find a way to measure it, it would make my life a lot easier. My guess is it would involved test notes and a fancy spectrum analyser or something like that to figure out the harmonics structure. A frequency response chart doesn't tell me about harmonics, and harmonics are what goes into making tone. Going back to the piano analogy. Take a piano. Going up the keyboard, press each key with the exact same amount of force and measure how loud each note is. That's analogous to the frequency response chart. Some pianos might be louder down low, others up high, but that doesn't tell me why middle A on a Steinway sounds the way it does. To find out why, you'll need to measure all its overtones & harmonics, and any resonances it excites in the piano's structure. That's what gives the note its tone, and why middle A on a Steinway & Yamaha don't sound the same. Now you gotta take that and apply it to headphones. Headphones have resonances, harmonics, and so forth. It'll affect tone. But to my knowledge, those measurements (if they've been done) aren't available to the public. Which I suspect is why my Grado 225 sounds more natural than my Senn 580 in certain frequency ranges despite having a more ragged looking frequency response. |
Originally Posted by 2100 Yup, my thoughts on the phones are not far off too. I think a small problem is that they are priced too expensive in the U.S, so it's not that good value for money comparatively. |
Originally Posted by Vertigo-1 I believe that ultimately it’s the lower treble/upper midrange area, or rather a lack of it, that’s responsible for the darkened overtone the HD650s have. |
Originally Posted by aerius Mostly agree with your comments on the midrange & treble, but the bass I found to be different. I had issues with it as well, but for me it was not enough perceived impact, not enough quantity, and the tone wasn't right. Yes it's fast & dynamic, but for some reason it doesn't feel like it hits hard, the opening to "Space Dog" doesn't knock me back the way it does on Grados or my K340. Not enough is pretty self-explanatory, I prefer PS-1 amounts of bass. Tone is little harder to explain. Think of the same low bass note being played on a Steinway and a Bösendorfer grand piano. It doesn't sound the same, each piano will have its own sound signature, or tone. And that to me is where the 650 falls short in the bass, in the lower bass, things just didn't sound right, especially low piano notes. With the 650, a Bösendorfer Imperial Grand ends up sounding more like a midrange Yamaha in the low notes. That really annoys me since I'm a Tori Amos fan, and guess which piano she uses. |
I would like to pose one question to the reviewer and also to other HD650 owners. There seems to be a very wide variation in the feedback on the bass performance of the HD650. The descriptions expressed describe the bass as possessing a remarkable, deep impact/ scale to sometimes being reported as anemic. I suspect that this variation has much to do with the ancillary components used in each case. If any users of headfi.com can clarify this variation in feedback it would be appreciated. I would have most interest in comments that use the SR225 as a benchmark for comparison. |
Originally Posted by chesebert $300ish off ebay is not bad |
Originally Posted by iDesign I would like to pose one question to the reviewer and also to other HD650 owners. There seems to be a very wide variation in the feedback on the bass performance of the HD650. The descriptions expressed describe the bass as possessing a remarkable, deep impact/ scale to sometimes being reported as anemic. I suspect that this variation has much to do with the ancillary components used in each case. If any users of headfi.com can clarify this variation in feedback it would be appreciated. I would have most interest in comments that use the SR225 as a benchmark for comparison. Best, iDesign |
Originally Posted by Vertigo-1 For some, it’s because they can scale to tremendously great heights with better and better equipment, turning them from merely very good headphones into true world class headphones (I personally haven’t come into contact with the associated gear needed for this transformation however). |
