How does the Mojo sound thru SPDIF? SPDIF has no RF/EMI.
Sennheiser HD650 & Massdrop HD6XX Impressions Thread
- Thread starter tangsta
dakanao
- Jun 8, 2012
No idea, since my music sources don't have SPDIF.How does the Mojo sound thru SPDIF? SPDIF has no RF/EMI.
Its also galvanicly isolated so no noise coming in from the source as well like usb, its a smoother treble but without the bass boost like @dakanao gets with with his jitterbug and usb cable. Any extra bass would be too much imo because the mojo already sounds rich in the mid bass with roll off in upper treble and sub bass. Its not a flat reference type of sound.
Yes, and SPDIF (Optical) is also galvanically isolated. That's why I'm interested.
auronthas
- May 19, 2017
Sensitivity should be SPL dB @ 1V rms, and efficiency as SPL dB @ 1mWHi, please comment if there's any error in headphone/IEM SPL, power, voltage, current calculation to determine how difficult headphone/IEM to drive.
Also, may i know what is the "norm" desired listening level ?
From previous investigation I can say that the comparison* between the HD650 and the K701 is way off, for the same SPL dB the K701 needs ~1.5 times more voltage and ~ 7.5 times more current so ~ 11 times more power than the HD650, others will liikely be incorrect.
* Using the measurements by Tyll at Innerfidelity, actual measurements on the same test rig as opposed to manufacturers unspecified numbers
auronthas
- May 19, 2017
Indeed, I used both sensivity and efficiency formula to generate the power, voltage and current required based on desired loudness @110 dBSensitivity should be SPL dB @ 1V rms, and efficiency as SPL dB @ 1mW
The K701 data I got from their specification as you mentioned may be biased …
I am not denied it.
gefski
"Desired loudness" 110db??????????????????
dakanao
- Jun 8, 2012
I would imagine the Mojo to sound the same with optical, as with the isolated setup I have with USB.Its also galvanicly isolated so no noise coming in from the source as well like usb, its a smoother treble but without the bass boost like @dakanao gets with with his jitterbug and usb cable. Any extra bass would be too much imo because the mojo already sounds rich in the mid bass with roll off in upper treble and sub bass. Its not a flat reference type of sound.
The bass doesn't actually get boosted, it's just that distortion noise in the uppermids/treble gets taken rid off, and so the bass gets more defined in impact because of that.
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
this might help http://www.apexhifi.com/specs.htmlHi, please comment if there's any error in headphone/IEM SPL, power, voltage, current calculation to determine how difficult headphone/IEM to drive.
if you click on the excel picture, you can download the file and use it with your own values to check or just see what operations he's using in the spreadsheet.
auronthas
- May 19, 2017
Thanks. I think I follow his website to generate my own calculation in excel toothis might help http://www.apexhifi.com/specs.html
auronthas
- May 19, 2017
Exactly I was wondering why http://www.apexhifi.com/specs.html used 110db as desired loudness. In my post earlier, i asked what's the "norm" of desired listening level."Desired loudness" 110db??????????????????
If we lower down desired loudness, the required power to drive the headphone will be reduced too, right?
castleofargh
- Jul 2, 2011
the loudness picked is a personal matter. ideally you'd pick a worst case scenario for yourself. I never listen to music very loud, and happen to have a way to measure the SPL out of my headphone, so I know what I need and have absolutely no need for some amplifier with a disproportionately huge gain into my headphone. but I use some EQ and replay gain and those have to be accounted for. so the actual signal is often 10 to 15dB(for modern tracks at least) below digital full scale. meaning that even if I aimed for 90 or 95dB SPL which is really the loudest I'm going to listen at night in my room with my HD650. 95dB is a level I can need when I measure the headphone so it's a nice limit for me. I still have to consider a safety margin of... maybe not the 10 or 15dB because I don't measure stuff with replaygain, and only about half the time with some EQ in the signal path. so maybe 6 to 8dB for some worst gain compensation from EQ, leaving me with a target of max loudness of at least 95+8 dB SPL. I'm confident that I would leave just fine with that. it might bot be the case for somebody else who enjoys music as loud as if he was at a concert(and some do).Exactly I was wondering why http://www.apexhifi.com/specs.html used 110db as desired loudness. In my post earlier, i asked what's the "norm" of desired listening level.
a different approach could be to consider that 115 or 120dB is where sounds start to cause pain to most listeners. so there might not be any reason to get a lot more.
some people think that more is pretty much always better, or they have their own safety margin over what's already a safety margin. I don't have many headphones and I absolutely hate having a hard time setting my desired listening level with a volume knob that makes music too loud before even reaching 9 o'clock(plus some have serious channel imbalance in that area of the knob, and the higher the gain, the more likely it is for background noise to also increase). that's why I avoid stuff that are clearly too powerful for my needs. unless they have convenient gain settings, or I can ask the manufacturer to lower those gain values before sending the amp to me.
anyway, the average Joe might not know how loud he's listening to music, and he might have no reliable way to know. I suspect that it's a big reason why people tend to consistently pick the more powerful amp among those they were considering. and it's hard to blame them, because while too much power can cause issues, not being able to get music as loud as we want is always bad news.
auronthas
- May 19, 2017
I get what you mean...
In short the ideal and perfect headphone/amplifier matching is important so not to miss any music details as per the Master Records and at tolerable listening level.
megabigeye
I thought 110dB (or 115, or 120, or whatever) is chosen to account for maximum dynamic range of music (plus whatever EQ is being applied) over the hypothetical maximum average listening level?the loudness picked is a personal matter. ideally you'd pick a worst case scenario for yourself. I never listen to music very loud, and happen to have a way to measure the SPL out of my headphone, so I know what I need and have absolutely no need for some amplifier with a disproportionately huge gain into my headphone. but I use some EQ and replay gain and those have to be accounted for. so the actual signal is often 10 to 15dB(for modern tracks at least) below digital full scale. meaning that even if I aimed for 90 or 95dB SPL which is really the loudest I'm going to listen at night in my room with my HD650. 95dB is a level I can need when I measure the headphone so it's a nice limit for me. I still have to consider a safety margin of... maybe not the 10 or 15dB because I don't measure stuff with replaygain, and only about half the time with some EQ in the signal path. so maybe 6 to 8dB for some worst gain compensation from EQ, leaving me with a target of max loudness of at least 95+8 dB SPL. I'm confident that I would leave just fine with that. it might bot be the case for somebody else who enjoys music as loud as if he was at a concert(and some do).
So, say I normally listen at 85dB, but on occasion I like to rock out at closer to 95dB, and the classical album I'm listening to has a dynamic range of 30dB. Keeping in mind that half of the dynamic range will fall below the average listening level, that means I need power for 15dB on top of 95dB average = 110dB max.
If I apply +8dB of EQ, then the total should be 118dB (though I don't honestly know how EQ affects average loudness).
Anyway, that's what I've read and how I think about it, though, practically speaking, I don't think I ever get anywhere close to those levels.
Maybe we're talking about the same thing? Or maybe I'm misled on the how and why of it...
