raybone0566
I've been listening to the liquid fire for the past couple weeks & it's excellent with the 650's. Very transparent, very resolving & smooth. ill be sad to see this go![](https://www.head-fi.org/attachments/1842249/)
Guys I'm not knocking the Ember at all, I've heard great things about Garage amps. I guess what I mean is that despite rolling 6-7 different tubes in the vali 2 it still sounded too similar to my magni 2. My Jotunheim sounds so good that I don't really want to bother with another amp unless it sounds significantly different (but still good obviously). I've had my eye on the BH crack for a while now after reading so many recommendations for it. Might be a while, I'm currently saving for a set of KEF reference model threes...
I have some KEF Ref 103.3, unfortunately they are in storage, not enough space in the place I live now to set them up, I think this is the last picture I took of them and its over 10 years old:
in the corner covered with a towel since the sun did shine on them for most of the afternoon, miss this place, the living rm was huge (16x33)
I like SS amps. I like tube amps.
I ******* hate tube-rolling.
what I imply is that if there are those variations between left and right channels for headphones even when the manufacturer tries to match them, then obviously we can expect to have not only the same magnitude of variations between pairs, but most likely even more.
a driver is a driver is a driver ^_^.
Hahah good to see you! And as straight to the point as always![]()
I'm using either my NAD, a little dot mkII, or the highly 'neutral' hp out of my audiolab dac at the mo. I've always thought tubes were the way to go with the 650 as IME they help bring out the holographic soundstage that the HD650's are very capable of and also to complement the smoothness (kind of adding chocolate custard on to chocolate pudding. Overkill for some - not for me).
Some prefer SS for the HD650 as it can bring out all the resolution and tighten up the low end. My only problem with some dedicated SS amps and the HD650, is that they can 'dry them out' too much for my preference (obviously generalising here with no specific amp in mind).
What amp gives the 650 the best balance of all of the above you mentioned, for say, under $300? What about best balanced and best bang for your buck, regardless of price?
For me in a under $300 amp it would be Asgard2 or Polaris, different sounding amps but both work with the HD650.
Best I've heard with the HD650 is Liquid Glass with some Ken-Rad or Sylvania chrome domes or EC Balancing Act (can't remember the tubes in them)
In what ways do the Asgard2 and Polaris sound different, if you don't mind elaborating a bit?
When I asked for best, I meant best value, but with no price limit. Is the Liquid Glass the best value or just simply the best at any price?
It's just that so many people say that a several hundred dollar amp is the best you can get and anything costing thousands is not worth the extra money.
