It's not about how loud something is. It's about control of the diaphragm. I really doubt any of the Dragonfly models are adequate for an hd600/650. These are not 300ohm headphones regardless of what the marketing material says. You really need to put some power into them.
I think a better amp would change your mind quite quickly.
this makes zero sense. it's not marketing it's electricity and how loud you'll listen to your hd650 totally determines how much voltage and power will be needed. if anything, marketing is what convinced people that they needed unlimited powaaaaa to drive a fairly sensitive high impedance headphone.
objective needs are assessed through objective measurements, not taste and gut feeling.
to control the diaphragm you have mechanical damping from the headphone, and electrical damping from the interaction between the headphone and the amp, where the impedance ratio will determine most of the result. if you lack current the sound will distort like mad so it's not a matter of sounding better with more current(more than what?), you have enough into the load at a given loudness, or the sound will be horrible. not just different from personal preference, but actually wrecked sound.
so while I tend to agree with the control of the diaphragm argument at an objective level, the fact is that many of the praised amps in here have high impedance and as such a very poor electrical damping ability. suggesting that for most people it doesn't matter, or that maybe they actually like it a little underdamped. or maybe they just like the little mid bass bump as a result, or maybe they just like those specific tube amps. and of course, maybe it has absolutely nothing to do with power and diaphragm control at all and people just assume it does.
personally I do like to have some headroom when it comes to power because I often make a heavy usage of DSPs of all sorts and they usually need to compensate the gain to avoid potential clipping in the process. as a result the amp will need to have all the headroom I will lose on a digital level. so I still tend to rely on this kind of vague estimates http://www.head-fi.org/t/197776/sennheiser-hd650-impressions-thread/27645#post_11806577 for myself I consider that if a source can do 100db into 300ohm at 1khz, it can do anything I'll ever need. I stick to 115db as a target when doing it for others because I don't know them and how loud they'll listen. less than my target loudness will make me consider my use, while a good deal more than my target loudness will simply make me avoid the amp if it doesn't have gain implementations specifically done for practical use around 1 or 2X gain. more is just impractical for comfortable volume setting of the hd650 and minimum risk of channel imbalance IMO. in short, I don't mind extra power as long as it doesn't create a problem for my use.
anyway, from that very very safe general approach of aiming for 110 or 115db
max into 300ohm, the dragonfly seems to come a few db short(not by much really, but the specs are based I imagine on a well behaved USB port, so that might deserve some more investigation when used on battery powered devices for example). IMO it mainly begs the question, is the user the type to listen at very loud levels with replay gain, heavy EQ, and stuff like that? if so, he might want to consider other options. otherwise for normal listening levels the little thing will do just fine in actual power and loudness needs with the 650. in practice most sources will do fine at reasonable listening levels. that's electrical reality not marketing, but of course it's only power and loudness, there is more to good audio than that. some sources may not be totally transparent, and the listener will then logically have personal preferences. that is true and should obviously matter to the user, but don't confuse taste with electrical requirements.
PS: for the anecdote, my O2 right now is set to output 0.03V(I'm not done with some measurements and leave it there out of laziness). even then I'm not at 100% in foobar. I'm considered a quiet listener and I don't expect everybody to enjoy music in the 60/70db area most of the time, but it would be lunacy to say that my sound isn't good enough because my amp lacks power. it could be improved on many levels for sure, but power isn't one in that usage.
