LazyListener
- Nov 30, 2015
@castleofargh
I wasn't implying any conclusions, or stating that power is the sole cause. I'm fully aware of correlation vs causation. I was simply stating my limited observation, and also from what I've read of most others' observations - that more powerful amps, when paired with higher impedance cans, tend to produce a fuller, rounded sound vs weaker amps that tend to produce a thinner, leaner sound.
I got the impression from your posts that you think power output has no effect on sound quality. Is that correct? I apologize if I misunderstood your posts.
My personal theory on the matter is that lower frequencies require more power to produce a certain SPL, whereas higher frequencies require less power to produce same SPL. Therefore, weaker amps are tuned to sound loud by using more of that power for higher frequiencies and less power for lower frequencies. The idea is to make it sound loud, not necessarily balanced. Amps with more power on tap are tuned to sound more balanced because there is plenty of power to go around for the entire frequency spectrum. Just a theory. Manufacturers want their relatively weak amps to sound loud, as louder amps sell more than quieter amps.
