To do the tights thing for protection of the drivers, it's actually quite easy.
Cut out a nice sized patch. Take off the pads and stretch the nylon over the drivers and clip the pads back over the top, trapping the tights.
Then I pull on the tights to get them really tight. They will slip with a good tug.
Then cut the edges of the tights away by pulling them outwards from the cup while cutting. Then they spring back and you don't see too much.
If you remove the pads again, the tights jump off!!!
Stops hairs going in.
