I didn't mean to start a vinyl war here but I had to state my opinion
There are many reasons I gave up on vinyl.
Some being...
Pops, skips and scratches.
Sounds like you purchased poor pressings. FWIW, I can't even remember when a record skipped.
The amount of space on vinyl before sound is compromised (the last songs on each side suffering the most)
That's true. This factor can be minimized with setup. Yes, back to that again.
OK...great vinyl will come as a 45rpm with two songs on each side (and spin faster for a better sound) but I already have a problem with getting up a turning a regular record over halfway through.
Either the sound on the last track is compromised, as you mentioned, or there's the alternative of a 12" 45 RPM pressing. Can't have it both ways.
This interruption can ruin recordings like THE RAMONES IT'S ALIVE where I truly didn't appreciate it until I heard the entire show uninterupted on CD.
At the same time, sequenced sides add another dimension to listening.
The thumps that are picked up by walking by unless you invest in a very expensive isolation stand. (my tip toes just didn't cut it with my wooden floor)
A very expensive isolation stand truly isn't necessary to handle this problem. It's a matter of experience. Your dealer may have been able to help with a home visit.
The quality of the vinyl used (probably not a problem today with the prices vinyl is going for)
I hate the cost of new LPs, as well. This being said, looking at the price index, they cost about the same or less than they did in the '80s
The The wow and flutter...I once had a record by Echo & The Bunnymen where they didn't center the pressing properly so it sounded like an old 45 without those old centering thingies (people over 50 know what I'm talking about
) (OK...I know CDS have been crappy too...Hello first pressing of EXILE ON MAIN-STREET)
The thumping from a warped record
A well-setup, high-quality 'table/arm can greatly minimize and even eliminate some of this, like thumps from a warp and the negative effects of an off-center pressing. A 'table with a reflex clamping system can remove the warp, altogether, during play.
And finally my personal experience of buying a $1000.00 Rega turntable that plays slightly too fast because of the power current being different from the UK (I live in North America.)
Did you buy a UK Rega? American motors are not the same as the ones in its home country. Ask me how I know.
I also spent another $500.00 on a highly acclaimed stylus that I found too dark and muffled.
Well, that's not a fault of the medium, if you know what I mean.
So my turntable has sat in the closet for the last 6 years
My only love for vinyl is the memories of hunting them down in the past.
Different strokes...
