Lorspeaker
- Nov 29, 2010
i would get the Lyr2 ...the power...and the twin lightbulbs
I've never owned a Woo and have never seen anybody mention it on Head-Fi, but whenever I have tried them at a show, they seem to be noisy with audible hiss over the phones.
That's the thing about tubes, and bad tube or two, and you will get a hum. And RF interference can also be an issue, and at shows there are phones galore in action. But I see much joy, in my future, with tube rolling....
I've read past this and saw the other replies and I'd like to add two points:
1) You are moving up the food chain, gear wise, and you might be at the point where your system is revealing flaws in the quality of recordings you are listening to. Maybe its time to look at the actual music, and not the gear moving it to your ears? It's just a thought that's usually overlooked. The term "the HD650 scales well" might be overused here, but I truly believe that. I'm normally a believer that the cost of amplification and headphone should be similar (like the old home amp to speaker ratios). But, with the HD650 I take zero umbrage with pairing them with an amp that way above the price of these cans. And that leads me to point #2
2) If you feel the desire to go to the HD800, or any other revealing can in the flagship range, its more likely then not going to be a commitment to other near flagship pieces of gear as well. My small amount of personal experience with the HD800 has led me to only want to listen to them through a top notch tube amplifier. I appreciate what they can do through top flight solid state gear (like the GS-X Mk2), but I don't find the sound to be very entertaining.
My 2015 HD650 New Year's resolution is hopefully going to be a near top flight tube amplifier that drives an HD800 nicely. I know that sounds a bit weird, but I never met an amp that nicely drives an HD800 that doesn't also do wonders for an HD650.
I've listened to the sennheiser hd800 on a Mcintosh MHA100 SS amp/DAC combo, and while the hd800 did sound a little better, I actually preferred my hd650, as I did bring my hd650 to demo next to the hd800, both on the McIntosh, and like I said, preferred hd650also, the hd650, as well add hd800, are 300 ohm headphones, meaning that they will pretty much only sound there best on a OTL type amplifierlow impedance headphones sound best on a OCL type amp (output capacitor less) amp, while again, hd650 hd800 need aOTL (output transformer less) amphope this helps!
But is it a good pairing? Also if you buy a used Schiit amp from a another person or seller, do you get any warranty on the item?
I'm not sure how the Schiit warranty works. I just bought a used lyr 2 yesterday and I got a copy of the receipt from the original owner, so hopefully that is all that is needed for any warranty work.
Man, going by some of the "advice" in this thread of late, one really needs to go top of the line with components to even glimpse the HD650's vaunted ceiling. Must be wonderful to have clouds part to an angelic chorus and have God rays beam a halo of euphoria around your HD650 for every listening session. Heathens with their cheap components and dirty mp3's need not apply. Amirite right guyz?
/sarcasm
