Sonic Defender
To be fair with this blind testing i will be using a blind fold(with a hole on one side) and the amp will be behind me and my wife she will be turning off /on the amp without changing the volume then she will switch between SE/ BALANCED mode.The amp is set to Balanced but i will go in the other room so she can decide if she will go SE or Balanced before we begin the test,I will be doing this 4 times and in between the test i will be in the other room so i can not see or hear if she is switch from SE to Balanced.
That's the spirit!! Do ten trials, and anything above 80% accuracy is good evidence. I'm about to do the same. I just spent pretty large money on a cable upgrade and I can directly test it against the stock cable. I'm going to get my friend to help me and I need to have a way that I can't feel the cable or see it. My instincts tell me I won't be able to tell the difference (but for $500+ Canadian I sure hope I do!). I needed a custom cable to use my integrated amp as it had no headphone circuit so I had a long cable made that taps into the speaker terminals so even if there is no improvement in sound due to the cables, I will still have a nice long cable that allows my to use my integrated. Cheers.
