i luvmusic 2
- Aug 27, 2013
Do CRACK and have SEX 650 times............
Nice did you buy it pre-assembly or build it yourself ?
I build both of them my self.THANKS!
I`ve been listening to the 650 for about 2 weeks now and I absolutely love the sound compared to my Q701. Unfortunately, they seem to give me somewhat of a
headache or a slight ear pain after an hour which I find very weird. Neither my UE900 or my Q701 have ever done this. I still will try to get used to it because I`d be very sad if I had to change them, they really do sound amazing.
Check you're not cranking them too loud as they sound so good at volume the temptation is to amp them a bit too much sometimes I find.
Is HDVD800 the best amp for HD650?
The price is reasonable and it's one of the stock CAPS used by Bottlehead on the SEX amp and it was recommended to me by one of the BH designer.For the Attenuator i can't comment on that i never used it on the SEX tried it on the CRACK but i don't like it so i replaced both of the POT with the ALPS BLUE VELVET Pot.
I though the attenuator you tried was some weird stepped series resistor pot and not the a ladder type stepped attenuator?
The Mill spec Dale resistors are a super choice for a attenuator they are very quiet I am using them in a attenuator fitted to my Sex amp.
This seriously might be the best headphone ever made....can't get enough
I've never tried the HDVD800 w/HD650 but I've tried many others & the best one by far is the one I own right now : Headamp GS-1. I've always loved the HD650 but with this amp they sound out of this world. Not a single detail lost in the sound and the impact is outstanding. A fellow Head-fier whom I ask advice to when I want to buy something (this guy knows his stuff) answered me this when I asked him if the HD650 had good synergy w/the GS-1 : (quoting him) : "The Senns can sound lifeless or cloudy on a lot of amps for the Dynalo amps really grab them by the balls and make them swing." (GS-1 is also known as a Dynalo amp). It doesn't stop there, I will be updating the GS-1 w/GS-X mk2 module which I've ordered. So in effect my HD650s will be driven by a $1,000 amp with an upgrade of a $3000 amp. Maybe it won't quite be as good as the GS-X mk2 itself but it'll be darn close. I can't wait to get the module updates and drive the HD650, my favourite HP period. I've owned the HD800 (2x), the T1 & the LCD-2 rev.2 amongst many expensive/elite HPs and I've always come back to the HD650. Some say it's because it's a forgiving HP which makes long periods of listening more enjoyable but I say it sounds better period, w/nothing lacking or to envy from more expensive HPs. If you're lucky enough to get the right HP amp for them they will simply blow you away. BTW the GS-1 is discontinued but if you're lucky you can find one in the for sale forum on Head-fi or other sites like AudioGoN & US audio mart to name a few. In my case I was very lucky to find one on Head-fi in superb like new condition. Anyways I've ranted long enough. This is my recommendation. I hope you find an amp with good synergy for your 650s, they're worth it (& deserve it ?)
