Wrote this about a day ago ... copied from overclock.net:
At long last ... my HD595's came in today ...
I've been listening to them for about two hours now and have some (premature) thoughts:
Number one ... they're some sexy looking cans. Love the design.
That said, ... there's much to be said for the various other aspects of the cans worth... fit, sound quality, driveability, etc.
/FIT/
The fit is perfect for mi cabeza ... lovely pads, plush velour, just the right pressure. Lovely all around on the fit.
I can find nothing negative to say about the way they fit my noggin.
/DRIVE-ability/
My listening tests were done with the X-fi in Audio Creation mode so that I could run in 'bit-matched' mode, thereby disabling any X-fi EQ, surround or otherwise settings/affectations that come matter of course with the X-fi cards.
The X-fi elite pro drives them to moderate levels ... decent sound and all ... just not very 'thick' and not very loud. In the unamped X-fi scenario, I had to crank the volume to the absolute max to get any sort of decent sound ... but it was still only medium level volume.
When I plugged in the XM4 amp, things got a
LOT better.
The additional juice provide by the in-line XM4 amp seriously transformed the sound. Thicker bass, highs and mids much more present and, well, just lovely.
Another thing that changed significantly when adding the XM4 in-line was that the sound stage became much more lively and 'animated,' wider and more realistic in all regards (really came to appreciate my amp a bit more with these tests).
Also, with the XM4 in-line I had a much higher volume ceiling compared with running the X-fi alone (unamped).
/SOUND/
One thing right off the bat that becomes apparent is that these cans do the high/mids area in an exceptional way. Not quite as sharp and crisp as my Shure e4c's, but still very pleasing and up front. Compared to the Shure e4c's ... the highs were just a tad rolled off in the finish but just as bright and apparent.
One thing I was pleased with, sound-wise, was that I immediately recognized that in regards to frequencies (not volume) the HD595's are a direct competitor to the great performance of my Shure e4c's. But the volume/bass category is another story for now (pre burn in) ...
The bass is natural and present ... though in no way would I call these bass monsters; granted, these new HD595's are not burnt in yet ... but right off the bat, the bass just isn't as potent (in identical listening circumstances) as my Shure e4's. The HD595's are close ... running a close second and all ... but the presence and tone is just not as potent (minor quibble, really, ... the air tight seal of the Shure's really makes the bass shine).
Overall, I'm completely stoked on the general sound quality when compared to my main listening cans (e4c's) ... very happy that they were so close in quality ... but I do have some complaints.
Number one ... the possible volume levels, in no way compares to what I can obtain with the Shure e4c's ...
The HD595's get quite impressive in volume, but not to the 'serious rock your brain' volumes that the Shures will reach.
What happens is this: when the HD595's reach a certain point, I'll hear a very sharp and very *wrong* sort of distortion that manifests as sharp, loud pops in either ear ... this threshold is changeable depending on the amount of bass I'm feeding them. Maybe this will change as the cans burn in ... maybe not.
Either way ... it's somewhat trivial as the level I'm looking for is probably outside the gamut of normal listeners preferences ... (think I burned my ears out a bit back in the rocker days ... see the OSAMT sig).
Needless to say ... the Shure e4c's handle higher volume levels with similar bass profiles ...
In fact ... I've never heard the Shure's clip/pop like that.
Anyway ... again, it's totally trivial because the HD595's (with amping) do reach very very acceptable levels of volume ... just not the brain bursting levels my Shure e4c's will reach. But those comments are made driving both sets through an X-fi/XM4 setup and for all I know things will change once I get a better desktop amp.
I wrote that about twenty hours ago and the sound has improved quite dramatically since then ...
I dig them and will most likely keep them.
My only complaint is the popping at volumes I'd like to listen to certain bass heavy rock tracks at ... totally scary sounding pops ...
Has anyone else run into this? It only happens at the 'damage your hearing' levels that bands like Tool and others sound great at ...
I'm wondering if it isn't that my Amp just can't send it a strong enough current for those volumes?
