It is not that common but yes I have seen a few pairs with that problem - there is a plastic spring built into the driver that presses on the ridges on the arm to stop the cup from easily sliding up and down. If that has a crack in it then the earcup slides up and down too easily and it can be very annoying. Inside warranty I would expect sennheiser would sort them out but if you are outside warranty then there is a ghetto fix -
Depending which ear it is ... Remove the cable clamp / name plate
Underneath you will see the offending bit of plastic - the is a strip down the middle, in-between the screw holes with a dip in the centre. ( some newer ones have a sticker over it which you will have to remove )
If you cut a small section out of a cocktail stick, roughly 5mm, it will rest perfectly in that dip and support the spring from behind
Then if it is the cable clamp side just screw it back together and the cable clamp will hold it in place or on the name late side you may need a little dab of glue to hold the name plate tightly in place. You may not so try it without glue first
As it is part of the driver, it is just as likely to happen on any HD25 but as I said... I have only had 4 or 5 with that issue out of may thousands that have gone through my hands.
