Hi Mr Rick - my issue with the 598 is that it's somewhat distant (?not as engaging as more forward headphones) - does that have to do with the drop of the Senns in the 1k - 5k segment? Both my Grado and Shure don't have that drop ... and are therefore more forward? Or is that unrelated? (And I guess it's more complex anyway....)
cheers
Lets look at a comparison of your 598 and the HD600.
You will note that both headphones follow a similar curve. Some might call this the "Sennheiser Sound"
Starting about 30 hz both headphones are very similar out to about 1000hz. At that point both headphones start to fall off, with the 598s down about 2db to the 600s.
The real differences occur at 10,000hz, where the 598 falls about 10db.
The dip from 1 to 5 Khz will be noticeable compared to headphones without the dip. As you can see, the 600s will be better and perhaps will be more forward.
The real value of a frequency response graph is the ability to compare differences to other headphones. I use them all the time to find headphones that will sound "different" than the ones I already own. I'm not a believer in one headphone sounding "better" then another. Better is so subjective, and will vary from person to person and is very dependent on the music material used and equipment driving the headphones. All come into play to form what you hear.
If you would like to perform your own comparisons, here is the site that I use for that purpose.
http://www.headphone.com/pages/build-a-graph
