Sennheiser HD 700 Impressions Thread
- Thread starter Windsor
Rob80b
Sorry for the double post, bu man that is just beautiful. Thanks for sharing!
Thanks
Ya I think so too, but I’d have to thank Gustavo in Argentina, the designer/manufacturer who has put us Rega owners on a much higher playing field with his, IMHO, affordable and beautiful designed and functional Tangospinner upgrades.
But the whole is greater than the sum of its parts so that there is greater control/interaction between the stylus and the disc which translates in better detail recovery, tighter/better defined base and most importantly, and I’m not exactly sure why, but a major reduction in surface noise which is a godsend if one wishes to listen to vinyl with headphones.
Now back to headphones.
Perhaps surface noise reduced because of lower vibrations on the vinyl?
pdrm360
- Jul 2, 2013
Hi folks!
I am interested in a pair of HD700 headphones. I would like to make sure I get a recent serial number so can you please tell me which approximate serial number you have and when and where you purchased your HD700s?
I did the same when I was buying the HD800 and the results were rewarding.
Cheers!
Antun
the HD700 headphones, themselves, don't have serial number.
pdrm360
- Jul 2, 2013
I'm seriously considering getting the HD700. I understand it's the perfect balance between the HD650 and the HD800.
And I have just two questions before I buy them:
1. How is the HD700 for rock music? rock, blues, jazz, psychedelic rock, hard rock... etc.
2. How is the HD700 combined with the WooAudio WA7?
Thanks a lot in advance!
1. Not bad
2. Good
fallingreason
- Sep 9, 2009
1. Superb, they are amazing for rock.
2. Wish I could let you know, but I do know they pair well with gear that is analog or warm in nature.
migasson
- Dec 11, 2012
Ok,
After trialing the Schiits/Woo's/Bursons etc..
This is what I think is the best combo by far for the HD700's Very happy And running it.. UNBALANCED!! It was still better then the rest.. Yep the Sennheiser HDVA-600
Get it now!!
Get it now!!
Head1
- Oct 16, 2012
I thought the Dragonfly did a decent job when I tested it with the HD700.
R Giskard
Used to work for HAD Audiolab
Previously known as Akatona.
- Jan 12, 2008
Hi and thanks for your reply!
I didn't know that! I was under the impression Sennheiser was going for exclusiveness just like with the HD800. It doesn't matter in any case, they still seem like a fine headphone.
Cheers!
Antun
R Giskard
- Jan 12, 2008
Honestly.....not much if any..but I do appreciate the extra 3dBs (6dBs with a balanced source) of gain with the balanced connection.... especially with vinyl.
Hi Rob!
You also happen to have the same amplifier as I do, the Bryston BHA-1. So as with the HD800, the HD700 is a good match for the BHA-1 I take it?
Cheers!
Antun
Rob80b
Hi Rob!
Cheers!
Antun
Hi Antun
I find the BHA-1 doesn’t do anything really special, like most Bryston amps I’ve owned over the last 25 plus years, it just goes about doing it’s job... supplying a clean, noise free, undistorted amplified signal.
The HD700s and even more so the HD800s are fairly neutral IMHO, so with the BHA-1 they are both quite chameleon in nature with each recording, “WYHIWYG”.
RobertR Giskard
- Jan 12, 2008
Hi Antun
Robert
Hi Robert!
Then the HD700 is exactly what I am looking for! I am looking for a pair of headphones that will complement the HD800 and at offer (at least to some extent) the insight into music that HD800 have. The HD800 is a rather fine headphone but sometimes I feel like using something else, perhaps a bit less clinical, and connected to something else in the system as I don't necessarily always use the Bryston.
In your opinion, are the HD700s more "friendly" towards different amplifiers? I have found that in order to get the most from the HD800, you need a top class amplification and source component. This is fine of course since HD800 is a top class headphone. But this is hardly a transportable scenario and sometimes I like to listen to a cassette deck or a turntable or FM radio shows in the other room and HD800 being what it is, isn't really suitable for that.
Cheers!
Antun
One thing to keep in mind with the HD700 is that the stock cable is terminated in a 1/4" plug, which should be taken into consideration with transportable setups (not to mention the general stuff like long cable, size, don't want to expose this level of investment to the dangers of the outside world). That said, it sounds good out of my DIY tube amp, new Creative Sound Blaster X7, and I haven't tried it but I suspect good things with my Yamaha AV receiver's headphone jack, so I'd surmise that the HD700 isn't so picky as long as you respect it with decent gear.
caracara08
Really tough choice, but I am going to stick with the HD650. My brain and its sensitivity to that small treble spike is the reason. The HD700 does almost everything so right. Such a pity =\ This thread has been an interesting read though because theyre so polarizing. hmm maybe Il give them another try tonight...
Kyno
- Jul 17, 2014
The treble spike seems to be something common with the 700, wouldn't something like the Bottlehead Crack help?
Total: 11 (members: 0, guests: 11)
