Angel III
Ok (I'm following you).. then come back here when you do some listening tests with the HD660S2.
Will do.Ok (I'm following you).. then come back here when you do some listening tests with the HD660S2.
Wow! You are 100 percent correct on all your observations of this recording. Listening via my ndh30 on a singxer amp.Just wonderful timbers all accros this recomposed version of Four Seasons. The balance, the extension, the separation, everything is exceptional and makes sense.
They're good amps but just a heads up.....as they have been copied.I am buying a well used base Lehmann Linear amp today. Thanks for the input!
Yes I have read about the knock-offs. This guy bought his from a dealer in Ontario so hopefully it is the real deal.They're good amps but just a heads up.....as they have been copied.
https://www.aliexpress.com/item/1005004213397655.htm
Another album and sound that gives me chill at every occasion is the original soundtrack from "The Mission", and particularly "Fall".Wow! You are 100 percent correct on all your observations of this recording. Listening via my ndh30 on a singxer amp.
As good as it gets.
What is a capsule? You mean a driver swap into another headband/earcups?It's weird. I can only enjoy these with a 650 capsule. Stock capsule is too smooth sounding. It's a bit dull to my ears..
It's good in cases like these that I have many 6 series parts strewn about
This brother took out the 660S2 drivers and put them in a 650 frame and then proceeded to re assemble the 660S2 after the demo period. I don't think he has the 660S2 anymore.What is a capsule? You mean a driver swap into another headband/earcups?
What is a "capsule" my man?
This is classic Sennheiser 6 series ignorance on display. The whole system is designed to be easily broken down and put back together and one can do so whilst causing absolutely no wear and tear. The headphones I returned then were in perfect like new condition. A 5 yr old could disassemble these HPs. You should stop talking ridiculous nonsense.
Thats exactly why i buy directly from sennheiser. Btw basically no difference in pricing. All or most sales are initiated by sennheiser.I can't imagine a single person here would be happy or content buying a 660S2 from Amazon knowing that its drivers were removed, put into a 650 housing, then put back into the 660S2 and sent back to be resold (very likely, knowing Amazon, as new). And I think you yourself would pass on such a unit if you had the background knowledge before hitting "Purchase New".
This was one of those examples that solidified my resolve to never buy audio gear from Amazon.
Are you saying that you bought a new 660S2 and moved the drivers again, or did you send back that 660S2 with the rom650 drivers after all?
Plus, you get pretty good deals on refurbished products, I paid around EUR 340 for my S2sThats exactly why i buy directly from sennheiser. Btw basically no difference in pricing. All or most sales are initiated by sennheiser.
