Rob80b
Thanks for the early observations.WORLD PREMIERE LISTENING IMPRESSIONS OF THE SENNHEISER HD660S2.
Disclaimer - The headphone is brand new with zero burning time and the following impressions are more like notes / thoughts after about 3-4 hours of listening.
Mid-range is mildly forward, all types of voices (especially female) are always at the forefront.
The star of the show.
This is a vocals-centric headphone but I don't get fatigued as I did with the 650.
The soundstage is very intimate, the music feels like it is radiating from inside your head but in an enveloping and holographic way.
In large symphonic works you are placed on the conductor seat.
In smaller ensembles you are part of the action.
Very, very solid center image.
I wouldn't call the soundstage too narrow but it is not wide either.
Imaging and positioning are on masterclass level while there is plenty of satisfying layering - depth"
Looks like they indeed got quite a few things right but hopefully just a matter of letting things settle in, but as a non "vocals-centric" listener which was my biggest gripe with the HD600/650, the focus on the centre image being always bigger than life, blob in the head, etc, etc.....which is where I had found the HD700 took a step forward IMHO and put things more into perspective but that was obviously due to the totally different design and driver placement.
You do mention..."Fast, staccato, crystal clear and superb layering" along with "Plenty of airiness, transparency and definition" but then I find this part almost contraditory....
"In large symphonic works you are placed on the conductor seat.
Imaging and positioning are on masterclass level while there is plenty of satisfying layering - depth"...may just be my interpretation but sounds almost open and claustrophobic at the same time. ???
But I guess the biggest "raison d'etre" is the base, I haven't heard the Focal Clear Mg but if they lean anywhere toward the HD630vb or Neumann NDH 30 it should be rather satisfying although the 660S are not bad just missing a bit of extension and body.
