yangian
- Sep 22, 2014
OK guys, help me out here. I just yesterday got a pair of Sennheiser 600s for $263 bucks (a steal) from Amazon in like new condition. So originally, I have a pair of 558s which I freaking LOVE. I wear them constantly and think they're basically about perfect for my tastes. They're musical, engaging, and the sound just seems to melt right into you. They're comforting and laid back and smooth.
So anyway, I was looking for an upgradeand since I loved the 558s, I figured Sennheiser higher grade would be great. I read the reviews for the 600 and they seemed to match what I heard in the 558s by the description of the sound and what I was looking for in a headphone. I could've got the 650s but the bass signature kind of threw me off them.
Anyway, so I got the 600s and I've had them on my head for a total of about 15 hours now and I'm just not loving them. The problems: they're fairly sterile and not engaging, and I think the treble is killing my ears. I've literally got a headache from these and my ears feel as if they've been pricked by pick axes. I had the same problem when I modded my 558s (by taking out the rubber sticky piece) to sound like the 598s which everyone swore by --- the treble/highs were just too sharp. I feel like the 600s are in between the 558s and 598s on that level...not as painful as the 598s but still causing earaches. (note: I never get headaches with the 558s)
The good: balanced, clean, clear, great fit...they're not as smooth or laid back, I feel, as the 558s. They're a bit more aggressive, if that makes sense. They're more analytical instead of musical. More "edgy". I'm fine with that, I can learn to deal....but the thing that really is killing me is probably the treble. The bass is slightly deeper than the 558s and sounds great. [never had any issues with the lack of bass on the 558s either] (I'm not a bass head, and I honestly like bass shy music)
Is there a way to tame that sharpness out? I am using the stock cable. Do I need to upgrade the cable or get balanced cables? I know it's not the DAC (Geek Out 450) because everything else I've ever played on the DAC sounds great. Any ideas? Is what I'm hearing normal?
I'm almost quite sure it's due to amplifiers. An amplifier works well with others does not mean i works well with 600. Few page before, I mention I have a tube amo. and a SS amp. The SS works well with 650 but bad with 600. It makes 600 sound dry/sterile and even harsh. But with tube, 600 sounds wonderful and 650 bad!! Try tube amplifiers.
