Pianist718
- Jul 13, 2012
If you're on a budget, keep the DAC.
Meaning...???
i am choosing whether to spend $260 on dac and amp or same amount on much better amp
I would go for the better amp first and then possibly for a dac later. Just my opinion.
Hey guys .... what's the best AMP and DAC for HD600? Under $700 total.
I tried Shiit Modi / Vali and to be honest ... not too impressed. (compared to my PC with old and low level sound card)
thanks
is it true that the pads wear off fast? some one on another thread said that and its cost 60$ for replacement
Is this an Australian thing like the water that swirls in the opposite direction in the sink?
That, by the way, is a common misconception. The water does not swirl the opposite way in the southern hemisphere.
http://www.snopes.com/science/coriolis.asp
thanks
Yea, similar experience for me too. I bought the Schiit Magni and was not impressed at all. Ended up selling it on eBay and I purchased the Asus Xonar Essence ST sound card. MUCH happier now. The Xonar Essence ST is a beast of a sound card and amplifier. Pairs very well with my HD 600 and my HD 580.
The Magni and Vali are quite different... The Magni is flat, dry, and gets the job done; the Vali is wet and sounds much higher end than the Magni.
