I bet it's not the upper treble that bothers you.
As for bass mentioned elsewhere - bass has several characteristics. Bass in the the 600 is excellent in terms of speed, very good in timbre. The bass extension, heft, and impact under 50 Hz. - not so good on the SS I've heard.
My ample Ragnarok 1 follows the basic curve in the bass. Starts declining at 75 Hz. Meh at 55 Hz, forget below 40 Hz. A parametric EQ can get them to 55 Hz solid, below that they flap around, and all you are doing is impacting the midrange.
However, the bass does go down to 35 Hz on my BHCs OTL with a little EQ - that's almost making it to the lowest stop on an organ. Soundstage is much better for 4-5 piece jazz and classical, and chamber rock the my SS. And the occasional issues in the treble are gone due to some added 2nd and 4th order harmonics - which adds a coherent warmth, and doesn't get all hazy/smudgey as soon over the top tubes can get. 800's also get the same treatment.
Interesting because the Rag delivers 3x the current but sounds wan in comparison.
