SilverEars
- Sep 18, 2013
I have the opposite opinion on the HD800S for EDM. They do EDM really well due to the lean nature and speed. For EDM, I find HD800 type responses do really well due to the less weight in the mids. That causes perception of speed.I'll just talk about the 600. It has great bass in terms of speed, timely decay, timbre. On a beefy SS amp (like my Ragnarok 1): Output is already going down at 80 Hz, well down at 55, and basically invisible at 32 Hz. That's not great bass all the way around - by definition. Now I put damping in almost every can I have including the 600 because I detest rattling and poor Q in the bass, so I am very conservative compared to most here in what I consider a proper amount of bass. But hold on:
Its well known that if you hear a piece of music on a speaker/headphone with very capable bass, that when you hear it on a table radio or ear buds with much less bass later, your brain sort of fills it in. Also if you listen to classical and jazz that are well recorded, you won't miss much under 40 Hz, because there isn't much there. So? Wait.
OTOH the BH Crack w/ Speedball (transformerless tube amp) somehow magically fills in the 30 Hz to 60 Hz range without making a sloppy mess of the bass from 60-250 on the HD-600. I measured it as well as my Rag and sure enough the Rag which is a beast for planar cans and speakers from 4 - 60 ohms, isn't pushing much current for the 300-600 Hz cans. The BHCS was so impressive to me that I bought the kit and am still buying up select pieces before I start the build.
Add on:
As for the 800 and 800S - the price of the new units increase expectations for what bass should be experienced. Even fans usually list this as the #1 issue - that or the annoying bits in the treble. The 800S absolutely will not play EDM music well. It doesn't handle low register piano or lots of organ music either. The 800S seems like it has a touch more bass, but that's because Senn increased the amount of 2nd order harmonic. The 800 is cleaner. I have NOT heard either one on a tubed amp that would do them justice - so I have to leave that as a possible answer like the 600 has.
Biggest factor would be what amp people are driving the HD800S out of. Most solid-states causes further upper-mids reduction and too lean of bass with too much treble emphasis. And this includes the priciest solid-states out there.
