bagwell359
I never heard he 500. But I have he400i and I like 600 much more than it
The 400 and 500 do not bear any particular relationship to each other. I have a 4XX and a 500 and the 500 is well better.
Although SR-009 has been praised as being at the top, such is the hype with these headphones that are considered high-end. And there will be disagreements. And the disagreements will be sourced from what each individual finds most important. For example, it's tonal balance for me, and that is at the top of the list. expensive headphones at minimum should be tonally balanced (given the crazy prices, it's warranted), and we know this is not the case. People may think that raised treble is resolution. More often than not, summit-fi headphone responses are toward the treble elevated side (not really balanced).
Some may think SR-009 should be at the top, and others do not see why. Count me in as one of them that do not understand why it's considered top. Even from when I first heard the SR-009 whether Blue Hawaii or not, it hasn't really grabbed me. I find it to be over-rated, and not better than dynamic or planar drivers, just different, and it's not better than a top dynamic or planar in a good setup. That's my take anyways.
I think electrostats are a bit hyped. It's probably pushed to the point of convincing newbies that lower-end STAX is better than anything, which is not the truth.
HE400i sounds nothing like a HE500, and this is with a HE500 in stock form. The HE500 that @bagwell359 has is modded and if its like my HE400 (also highly modded) they really are quite different from what the stock sound signature is.I never heard he 500. But I have he400i and I like 600 much more than it
Well I meant that people buy headphones that they like, not that they always buy the same type of headphone. My stable is similar in being diverse with tuning as well. As for experience, I have not owned the HD600 for even a year yet. And my TOTL experience is admittedly limited, as I don't own any current TOTL cans (which I cannot afford, nor will I ever be able to), only in-ears, of which I have the 8.2 Harmony and Vega with an Andromeda arriving tomorrow. I do however own the previously TOTL LCD-2, which you also own, and in my opinion it doesn't do anything better than the HD600. I find that bass extension flat to basically zero (from a certain frequency down) is neither a positive or a negative, and doesn't really influence my enjoyment of a headphone. I also don't think that small little bits of grain or lack of resolution in comparison to other "better" cans are really flaws. My personal headphones journey has made me conclude that a headphones only true goal is to present the music as accurately and naturally as possible, and in this regard the HD600 wins by leagues over anything I have ever heard by far. When I listen the them, the HD600 disappear and I hear the music and nothing else. Which is not to say that I don't like other headphones, I own many and love almost all of them. So I'm still of the opinion that the HD600 doesn't have any real flaws, and thus why it has stuck around for over 2 decades. And once again I'm also not trying to dissuade you, just that I hear things differently
Like you I have a HD600 killer: Ypsilon S1 custom build (the HD600 is one of the few headphones that I sold off since the small peak at 3.5-5khz bothered me at times and I've noticed that I'm not the only one) but I have headphones that are much brighter but since their treble peaks are higher up they don't bother me like.I agree, I have been trying to keep a low profile with my opinion. The HE-500 all by its lonesome modified in a fairly common way is the single can I have that buries the 600 - in particular when it comes to "holistic" sound. I did not cobble up the best of various cans to shoot down the 600. I'm a booster of the 600, but it can't stand up to the HE-500 here. If you're within driving distance of Lowell MA, come on by and try for yourself.
Well sure, I expect a headphone costing many times the price of the HD600 to exceed it in performance
I am not really a believer that the industry has changed leaps and bounds, at least not in be-all end-all sound quality. Because in the end a TOTL headphone is only chasing down that last 5-10% performance
and I am willing to argue no headphone blows the HD600 out of the water to such a degree as to replace it.
I still think the HD600 is kind of perfect, but you're also entitled to your opinion as well.
I have never really been an Audeze fan. I find their cans over-rated and over priced for the performance. Perhaps people have affinity for the look and build, but definately not the weight. Performance, weight, and price wasn't good.Actually the 600 > LCD2. I bought used it used after hearing it a few years ago, ugh. I had a friend of a friend haul over his and while mine were defective to an extent and I got my money back I still didn't like his LCD-2's at all. I just leave them in my sig so I can keep dissing them. Voicing is all wrong.
I don't really care what happens under 30 Hz, I hate any falseness in the bass so the 600 mostly does it for me, but they fade under 55 Hz and basically done at 42 or so - that's a lot. I do listen to a lot of bass: 600's are great with snares and rototoms, but I listen to electric bass, acoustic bass, cellos, violas - and the 600 won't growl, expand, sustain - it goes as far as it goes and stops. It's not right, so it must be wrong.
I was there a year ago. No longer.
If you've only seen 7's you don't really know what a 10 is.
May I ask you what kinds od genre you usually listen?
Their tuning either had odd mids or upper minds.
That's a broad answer:
remastered classic/indie rock
various female vocalists (jazz, indie, small ensembles, classical)
classical (prokofieff, really all the Russians of the past 150 yrs)
jazz (late 50's thru mid 70's)
I do listen to labels too: chesky, 4AD, cherry red, factory, MOFI,
no rap, country, hop
I see. I almost only listen to classical, symphonic work.
I always thought Hifiman generally does well with female vocals. Sennheiser open headphones, classical. I'll admit Beyer/AKG/Grado are areas I'm not all too familiar with.Yes, built like tanks. Too much bass, missing upper mids/lower treble and also upper treble. I hear the LCD-4 is a great can, but that's well out of my price range, and I like HFM tuning more than Audeze/Beyer/AKG/Grado schools. I really want to hear the latest from some of the newer outfits and of course HFM.
I have to say I'm surprised that classical and jazz (not elevator soft jazz) have both lost so much popularity since 1975. For both the players and audiences - there is so much more than is visible to the casual, and very enriching.
I grew up with classical and jazz due to my father. Lots of visits to see the BSO, but not the Pops. My brother started playing the Animals in the mid 60's and took me to a Led Zep concert in 1969, and two Pink Floyd concerts in 1971.
Guess I'm just carrying my early experiences forward.
