bizkid
- Jan 18, 2006
Does the HD600 change with burn in?
oh sure, don't get me wrong, the readers are always the victims. I was just saying it would be good for them to have a "skepticism starter pack". ^_^
as for reviewers, I found that it's really hard to have them make things clear between facts and impressions. after all, it's not like pro reviewers are any better at separating facts from feelings or how the sponsor is paying part of the bills.
I rely on measurements so much because I can't really find reliable information otherwise. so I'm with you all the way. it's not easy to find good intel and preconceptions(on all sides) certainly don't help.
I have plenty of skepticism, but if you're just starting, you have no reference and it's hard to know which snippets of information actually apply to you. A quick scan of any audio equipment thread may yield many people that assert that this piece of equipment has a neutral sound signature, but without reference, one doesn't know if that sounds neutral to yourself or not at all. In my case, I value a neutral sound, but what I find neutral, most people seem to evaluate as either bright or bass light.
Measurements can be useful, but suffer the same problem. What measurement graph corresponds to what I find neutral? When does bass fall-off register to me as not having enough bass extension? When does a treble spike become bothersome / painful? And perhaps most difficult of all: what shape does the mids need to have to not sound neither recessed nor boosted?
In the end, there is no substitute for listening, but auditioning in a shop will not always give accurate results either. Plus there is generally little in the way of headphones to audition around here, at all. For in-ears this problem is even worse, though at least I know I can usually rely on ljokerl's word, because we both seem to have a similar idea of neutrality.
It's good to avoid the marketing trap. I believe that once you have a quality DAC and or amp, easy enough to find, the story about scaling is more about marketing than appreciable sound benefits. IMO belief is a scary tool for marketing and forums. I believe that headphones are where you'll set the stage for your listening experience.
I don't know if you'd need a quality DAC, there doesn't seem to be much sound quality difference between the different DACs that I've tried, mostly in sound signature. A good amp can be useful, if you have hard to drive headphones. Or if your DAP has a really weak amp section. But there seems, to me, little point in getting a DAC/amp that costs more than your headphones (which seems to happen a lot on Head-Fi). As you say, the headphones have the biggest impact on sound (quality and signature).
Is it me or are these really efficient despite the high impedance?
Full potential or enhancements to SQ aside, my onboard soundcard is able to drive them loud enough.
I'm curious if other JRiver users could give me their opinion on my low bass boost attempt with the HD 600. I hear it as an improvement, but I would like to know if it is just me. I use 3 low-shelf filters to gently boost:
1st 80Hz Q=0.4 +2db
2nd 60Hz Q=0.8 +1.5db
3rd 40Hz Q=0.6 + 1db
I'm just starting to try this, and I have no idea if it is a bad idea in terms of basic EQing fundamentals. I am trying to see if multiple adjustments is somehow better at restoring the low bass than one larger boost. My logic, which might be flawed so please any input is welcome is that I want the 80Hz to spread out the most with both of the other adjustments being narrower. The db boost is I think modest, but again all feedback is welcome. I might actually be creating more issues than I'm solving.
1st 80Hz Q=0.4 +2db
