Anyone else experiencing bass problems with the regular HD 598?
Whenever I crank up the volumes, the bass starts overpowering the song and distorting the vocals, it's super strange.
I had the same thing when I first ordered the headphones a year ago. Sent them back because I thought the drivers were damaged and got refunded.
Now I tried to give them another chance and the same problem occurs which makes me think this is something common, but I've never read anything on this forum about it.
What type of distortion are we talking about here? I've never heard my open 598 SE buzz or "fart" like a woofer does when overwhelmed with bass. With a woofer, you get those nasty noises when the cone reaches past its excursion limits and slaps the voice coil behind it. Headphone drivers are designed differently, and while some of them do create this obvious, buzzy, over-excursion distortion when pushed too hard, I have never heard my 598 cans do this.
There is no doubt in my mind that the 598 DOES DISTORT when challenged by very loud, bassy material. But the way the 598 distorts is pretty elegant...what I experience is not buzzy at all. It's more like a compression of the sound. If you know what a hard limiter plugin sounds like...think of that. It's just like the amplitude of the bass hits a ceiling, so that much of the bass information beyond that point will be lost. Higher on up the frequency spectrum, there is similar a loss of precision and detail. I believe this is because the driver is vibrating so much, and dedicating so much of it's surface area to try to produce the bass, that it can't really render the mids or even the treble with precision either.
So listen for a compression of the bass amplitude along with a muddying of detail, which extends up the frequency spectrum to some degree. That's how the 598 distorts to my ears.
At moderate listening levels and with decent amping, I think the 598 handles bass well, even though there isn't much low bass without the help of EQ. I enjoy a 3 dB boost via a low shelf at 50 or 60 Hz. Even with the boost, the 598 won't distort until the volume is cranked high. And, yeah, I suppose if you set your volume to deafening leavels, I assume even the buzz-averse 598 would enter the farty bass territory, as any driver of any type probably will. Never tried it!
