RockStar2005
Perhaps to deter mod-itis running rampant these days.
Yeah probably. lol
They aren't "trying to hide" anything. Glued main driver chambers are standard fare in closed-back Sennheisers.
My HD598CS came half an hour ago, so all I can say so far is about argonomics. They're super tight so tight it's almost painful. Maybe because they're new? And I'm not talking about the band, which is super comfy and light on the head. I'm talking about cups super tight in fact left cup is slightly touching my ear and I have small close to head ears. Another thing I dislike right from the bat is the remote on the shorter cable, which is situated too high. It touches my chest and it's super evident and annoying when listening in t-shirt.
Actually you are right. I remembered the Urbanite also had the driver glued shut. Thought it was weird but it seems like they indeed do this if the Urbanite was glued as well. I wonder what's the reason. Sealing the driver with a piece of plastic and a sloppy hot glue job didn't look right to me, but what do I know about headphone manufacturing.
My guess is the reason is to seal the driver for proper bass response and sound quality tuning.
My HD598CS arrived today and I've been hoping to use it for 70% music and 30% conference calls at work. Connecting them to an iphone 6 and playing music from Amazon Prime, I wore them for about two hours today and think they sound better than my HD497 or the Momentum 2.0 bluetooth. The iphone 6 didn't seem to have trouble driving it as long as I kept the volume above 20% on the phone. At 30% to 40% volume, it sounded great and bass was good.
These fit over my ears completely and were comfortable for the two hours. They didn't seem too tight or loose and I generally wear XL size hats. I'll wear them for more time tomorrow and see how things feel.
I had that issue with "tightness" with the original 598 and the 598 SE as well. But I can't say I've had this issue AT ALL with the Cs.
Your ears are touching which part of the cup??
With regards to the cable, I wouldn't even use that one as people on here have said that in-line remotes can introduce mild amounts of distortion to the sound. So I stay away from them like the plague. lol Maybe I wouldn't notice a difference, but I dunno. So instead you should either get the about 4' braided cable or else the about 4.5' non-braided cable (both are proprietary for Sennheiser headphones). I got the braided then returned it cuz I don't like braided cables, and instead bought the non-braided. The non-braided has the same indent for "twist and lock" into the headphones, but for some reason it won't actually lock in. But I don't care since it still does snap in and that's all that really matters. The braided one does lock in though. So those are your options. The non-braided (if you choose the USPS shipping option) is like half the cost of the braided, and that's including shipping.
Note: Per all the user reviews, you won't notice a change in sound with the braided "upgrade" cable. I only had bought it b/c I didn't wanna use the in-line remote cable and the other cable had a 6.3mm connector which doesn't do my Oppo HA-2 any good. lol
So what's the difference between HD598Cs and HD569 ?
When the band is stretched too much earcups collapse on ears. Adjusting the band to a more snug fit made them much more loose therefore seems to almost solve a problem with inner cup touching the ear, though sometimes it feels like one ear is still touching something slightly.... Besides it's worth noting the packaging is not the best for this type of earpads. As soon as i remove them from the box the earpads were crushed and needed time to get back to their original shape. It was super obvious internal box foam was squeezing them therefore making possible to touch my ears.
Thanks for advice about the cables. I will definetly get one. Do you know any cable, which is super flexible? Fabric cable would be the best, but I haven't seen one dedicated for HD598 series
