Dukedudez
- May 31, 2011
Do you guys think that a Cowon J3 will drive these well?
After letting my HD598 burn in for a countless number of hours.. my opinion about them has only elevated. The bass, which was muted and quite subdued out-of-the box, has livened up considerably and now has fantastic body, impact, and extension. How it sounded out-of-the-box is a far cry from how it sounds now. The treble smoothed out considerably but remains crisp, airy, detailed, and extended. The midrange, an area of this phone that has always sounded awesome and was the main draw, has a more complete timbre since the bass response has matured. The 598s sounded fairly lean across the spectrum when I bought them, reminding me a lot of the DBA (before I got the comply tips for them).. now they have excellent weight across the spectrum while the instrument separation is in particular quite good. Rock guitars leaned to the brighter side initially, but after burning in, have great weight & crunch through the midrange and sound much more accurate and engaging.
These are amongst my favorite cans and rank right up there with my beloved FA-003..
Even unamped from my laptop, these sound astonishingly good.. I listen to them on a daily basis and haven't found myself reaching for the Arrow or MX-1 in quite some time. The only thing that really frustrates me is having to use the 1/4"-1/8" adapter.. since these are used primarily with my iPhone & laptop, the adapter is a fixture on the cord and its size makes it cumbersome to deal with. I'll be investing in the Grado 1/4"-1/8" extension pronto, I love the fact it's got a right angle plug too... are there any other recommendations for quality 1/4=1/8" cable adapters terminating to a right-angle plug?
About to plonk some coin with these babies.
So tell me, how much "burn-in" should I expect for the phones to flourish? I know I will just listen to them as I go, but curious to see. Some of you have complained the bass was anaemic, but then after burnin, they seem to have more impact.
I will be listening unamped for the time being.
[size=x-small][size=x-small]Sounds good FlySweep. Thanks for your detailed analysis. From the consensus that I got here based on the feedback, I think the 598 should suffice for my budget. [/size][/size]
[size=x-small][size=x-small]Strictly for home use only, I've got my Monster Coppers as my portable. The 598's look awesome! Took me a while to like the colourway, but looks spiffy I must say.[/size][/size]
[size=x-small][size=x-small]50 hours is quite adequate. Not too fussed about that. The shop where I plan to purchase has a 21 day return policy, so should be plenty of time to burn in. I'm usually sceptic of burn in placebo effects, but I think you guys have experienced much better results, so I'm happy to trial it.[/size][/size]
[size=x-small][size=x-small]It sucks that you can't do a cable mod for this. Was looking at Moon Audio, but no mods (Damn you proprietary cable) [/size][/size]
