I'd be really interested to see your measurements - this would be awesome. BTW, do you have any papers/theory you can point me to regarding the effects of the location of the damper in the tube? I can't see a reason for the location being important, given the relatively massive wavelength of even the highest audible frequency. (Assuming we're at sea level with c~340 m/s, the smallest audible wavelength would be around 2cm.)
There was an interesting post recently on the main SE846 thread where somebody claimed that the fabric dampers in the stock filters actually ARE Knowles dampers. Can anybody confirm that? If they are, they don't seem to correspond to any of the dampers sold on Mouser. Unless, of course, the differences in sound are somehow connected to the removal of the filter tube itself, which seems a bit tenuous, but who knows...
Well, isn't that what happens with any filter change that shifts the FR towards the low end, e.g., a switch from stock white to stock black? In reducing the mids/trebles, the bass frequencies are naturally more prominent in the signal. I think I would argue that isn't placebo
There was another comment recently in the main SE846 thread (might have been the same person as above) who suggested the improvement was only because there was a couple of dB bump with the Knowles dampers. I haven't measured carefully enough to know if that's true, but if you can get the FR you want with less damping, that's a good thing in my opinion, because all these dampers tend to preferentially kill the very highest frequencies where all the details are. I don't even know how you'd do a fair AB comparison with these things. Would you try to match OASPL? Or would you try to match SPL at a given frequency? And if so, which one? (And isn't that choice arbitrary and/or dependent on what you're listening to?)
I found all the Knowles dampers clearer-sounding than any of the stock filters. They all seem to have less ultra-high frequency roll-off. Also, they're so cheap (and I'm still giving away the sleeving/cable insulation cover for free!), they must be the best value-for-money mod in the history of audio.
Yep, it's in the post
