Jamnperry
- Nov 8, 2012
I think my flush cuts aren't perfect. I'm a pretty clumsy 60 year old and can barely see them! But I'm getting better at it.
Most people out there looking for an upgrade to their sound quality probably consider upgrading their headphones first, and then perhaps their source (e.g., DAP). If you already own one of the worlds' best headphones (the SE846), you've probably already worked your way through the black, blue and white filters and found your personal preference. I had been using modded blue filters (blue filters with the tiny pieces of foam removed) for more than a year and was pretty happy with them. Thanks to Jamnperry, I've now discovered something better, which I highly recommend to all SE846 owners
I should start by saying I'm a huge skeptic when it comes to audio. I have never been able to hear differences between 44/16 red-book CD/flac and 96/24 or 192/24 "hi-res" equivalents (from the same master) and have never seen any coherent counter-argument to Christopher Montgomery's now famous blog (https://xiph.org/~xiphmont/demo/neil-young.html) which implies that, in fact, no human being should be able to hear such differences. I'm also a bit of a DAP and cable skeptic. It's not that these things don't make a difference to the sound - I know that they do - it's just that those differences are usually smaller (and much more expensive!) than advertised. So I was a bit skeptical that these Knowles dampers would do much for me. But I can now say, for those of you out there looking for an upgrade to your SQ, the Knowles dampers discussed in this thread represent one of the best value for money upgrades you can make to your SE846. I would go further - I think these are one of the best upgrades you can make, regardless of price.
Jamnperry was kind enough to loan me some of his Knowles dampers and I spent about a week measuring them and listening to them. They're tiny little fabric-based dampers that come in a variety of colors indicating their specific acoustic impedances, given (curiously) in ohms:
Gray: 330 Ohm
White: 680 Ohm
Brown: 1 k Ohm
Green: 1.5 k Ohm
Red: 2.2 k Ohm
Orange 3.3 k Ohm
Yellow: 4.7 k Ohm
Generally, as you'd probably expect, the sound gets darker as you increase the resistance, although things seem to be somewhat complicated by the resonant peaks of the headphones in question. I found the brown FR to be reasonably close to those of my modded blues, but with a bit more slam in the bass. Surprisingly though, I also found that virtually all of the Knowles dampers I tested improved the overall clarity of the sound, regardless of the resulting FR curve.
These dampers are tiny - too small to fit in the SE846 nozzles. So Jamnperry had the ingenious idea of first inserting them into tubes cut from cotton swabs. That seemed to work ok, but I found they didn't seal perfectly in the tubes. My plan B was to first insert the dampers into tiny pieces of cable insulation. (I have tons of different sizes of cable and just found some bell cable that fit.) Here is an orange damper on its own:
And here is a red and a brown damper inserted into the plastic cable insulation:
These then fit snugly into the bottom of the metal nozzles of the SE846, replacing your existing black, blue or white filter tube:
I highly recommend trying these! They're available from mouser.com. You'll need to pay a bit for shipping and the dampers are priced individually, but less than $1 each.
Kudos to Jamnperry for starting this thread and many thanks to him for the loan of his dampers. I am now a loyal follower and a skeptic no more
Mind to share where to get and what's the size for the cable insulation? Thanks
