This has been an awesome thread. Thank you.
After trying all different filters, positions, with or without the Knowles SS ring, I’ve found what I think is the best mod: a green Knowles screen only, at the iem end of the white filter tube.
I removed the stock one (which I believe is the Knowles brown screen) and replaced with green.
In my case I pushed it out of the SS ring directly into the filter tube, but you can purchase the 1.78mm screens only too.
I’d describe the sound as close to the std white filter but with no sibilance or fatigue, and I swear it’s more extended, but I’ve no measurement devices to test that. It sounds great!
Since I posted about my green filter I’ve been experimenting more with adding foams, to see the effects of thickness and location in the tube. TBH it was looking back in this thread and reading Unispeed’s posts from 2019, that inspired me!
While the green filter sounded great at the time, I started getting somewhat annoyed by some treble peaks, especially one that sounded like a squeaky wheel. I can hear that same peak in the stock white and red filters too.
I first tried the ‘thick green’ mod by taking a foam from one of my black filters (I was never going to use these anyway), cut it in half and added each half to my two green filters,
I found the sound to be heading down the muffled road of the blue and red filters, but then I pushed it all the way down to the screen end and … OMG - incredible clarity. Still had the airiness and 3D stage but much cleaner too.
I rocked this for a few months before the bug got me again. I could still hear that squeaky peak and I felt the resolution wasn’t great. So I extracted that foam out and started again, from the open (ear) end, I tested it and pushed it down another 10%, again and again - until I got that high treble peeking through. I had these half foams about 80% the way down.
I will post photos here, but read on because I’m not finished!
This one was great for a few months, but again I got slightly irked by these damn peaks (no wonder Shure shoves all that foam in there, much to our annoyance!)
I made another green filter - using my remaining black tubes, replaced the red screens with green screens. Then I took two of the whole foams from these black filters and did the same as before - one whole foam in each tube, started at the open end, which sounded dull, and then trial and error, I finished up with it about half way down the tube when I hit nirvana!
If I compare this to the stock red filter my new ‘superthick green’ (actually just one foam) just has a better 3D soundstage, more clarity, excellent resolution and no annoying peaks. The red sounds like there’s some cloth stuck in my ears.
Again, it’s ridiculous Shure never used the green screen. So much better than the white brown and red they use in their stock filters.
