Big thanks to
@unispeed for sending me his final (never say never though, right?) revision 6 engineering mod
Here are some comparisons.
Firstly, the usual preamble and disclaimers about taking all these measurements as a
relative comparison. Your ears are unlikely to respond exactly the way my coupler does, however, the comparative trends should be similar. Secondly, the following measurements are all raw, normalized to 94 dB @ 500 Hz. Thirdly, bear in mind that eartips have an enormous impact on frequency response. Just to remind everybody of this, here's a comparison (using the "Trishd" mod) of three different sets of eartips - Comply P-series foam, Shure medium olives and SpinFit Cp240 silicone tips:
I recently found myself in need of some really good isolation, but didn't want to go full Comply-P-series foam. (Comply foams isolate really well, but roll off the upper frequencies.) So here, all subsequent measurements are made with SpinFit Cp240 eartips. My reference point for each measurement is the "Trishd" mod. First the stock filters...
Stock white. Main result, relative to Trishd mod, is more mid-range:
Stock blue. Main result, relative to Trishd mod, is marginally more mid-range and less lower treble:
Modded blue. Main result, relative to Trishd mod, is more mid-range (similar to white, but not quite as much of an increase in the mid-range):
@unispeed's engineering mod, revision 6. Main result, relative to Trishd mod, is less mid-bass, more mid-range, less lower treble:
I tried pushing the Knowles' damper farther down the filter tube to see the effect. Starting at roughly 1/3rd the distance down the tube (above), I then went 2/3 and 3/3 (as far as it would go). The effect is a more pronounced version of the above mod in regards mid-bass and mid-range, but the treble starts to increase now too:
The effect of tempering the mid-bass is quite interesting. This is probably closer to the Harman target in that region. Along with that, you can also get an overall increase in treble if you push the damper in far enough. I found it was possible to reverse this mod (if you're careful) by hooking the damper with a small watchmaker's screwdriver and pulling it back out again.
My personal favorite mod is still the "Trishd" mod. I prefer its sound signature, the mod is free and doesn't require any other components, it's easy to do and easily reversible. But there's no right or wrong here. It's all down to personal preferences, so go wild and see what works best for you
