So Alcophone when are you going to send your dac back to Schitt???
I should receive it tomorrow. I'm gonna make sure everything still works right and will do a blind A/B starting Monday by turning Yggy & DX7s on at the same time after having been off during the weekend. The DX7s will be fed via USB, the Yggy from the DX7s's coax out. The most practical solution. Actually, I can feed both DACs from the DX7s's coax out with a splitter and identical coax cables, the USB to Coax converter in the DX7s is completely independent from the rest of the device.
A friend will hook them both up to the Gustard H20 with identical XLR cables, and cover things up so I don't know which one is connected to which input.
Since the DX7s fades in its output after regaining a signal, and since the Yggy is a hair louder, I have to be careful. I won't simply switch back and forth, rather I'll pause the music, turn down the volume, switch, hit play, wait a few seconds, increase the volume and start the song again. Playing music while increasing the volume is necessary to set it, while also masking the H20's relay clicks to some extent.
I'll do that until I feel like I can identify the DACs again. Should be easy at some point based on the sound stage depth, but warmup is an unknown factor for both DACs. Since getting the H20, my Yggy has never been turned off for more than 30s or so, and I have never left the DX7s on for more than a few days (usually turn it off at night).
Once I'm satisfied with that, it's either off to Schiit, or off to
@atomicbob or
@jude if they are interested. Once it's back from Schiit there wouldn't be a point in someone else taking another measurement (other than Amir, I suppose) because the doubters will just claim Schiit fixed it the way they fixed Bob's and Jude's, at least if it measures better.
