Sure.
And thanks.
It's headphone based. Primary source is PC running JRiver Media Center and a library of redbook and hi-res FLAC files. That's connected to Yggy via USB and a Moon Audio Black Dragon USB cable. I have a pretty nice soundcard with optical and coaxial digital out, but it isn't capable of switching sampling rates automatically so whenever I hit a hi-res audio track I would have to go into the audio control panel and change the sample rate. USB and ASIO solved this annoyance, so that's what I've stuck with. Everything in the system is on a Tripp-Lite surge supressor, a commercial model but nothing fancy or audio marketed. There are two tube amps connected to the Yggy: a Dragon Inspire IHA-1 by Dennis Had, and a custom made 45 DHT built by forum member 2359glenn. These are connected to Yggy via Signal Cable Silver Resolution cables. From there my primary headphones are LCD-2.2 and MrSpeakers Ether (pre Flow). The LCD2 has a Toxic Cables Venom cable on it, and the Ether has a Norne Audio SolvX cable on it (which I've been very impressed with). At present there is no power conditioning present. The Yggy does have an aftermarket power cable on it, but nothing too fancy. I can't even remember what it is, I just gave it a spin to see if I could hear a difference.
My feeling is that the USB is probably the weak link in the chain, with dirty power issues being a big unknown that may be nothing or a big problem. I've seen a lot of people mention using high-end USB>SPDIF converters but I haven't absorbed enough info to feel confident digging into that. My hope is that if USB is giving me issues my upgrade to Gen 5 will help, which I plan to do at some point this summer or fall.
