5genez
On so many levels I'm offended by your comments.
You want to play with your fuses but you buy a DAC from a company that won't support you after you mess with your new toy.
Yes ... I used to work for a high end shop and also as a repairman for a TT company... and have confidence that I could open the case and change a fuse. Nothing else.
You complain that because you have less means, your opinion carries more weight than someone whom you assumes has more than you do.
No, that was not my complaint. My complaint was treating me like I can just change to another more expensive DAC if I do not like my situation.
By the way... Is it true? That your Krell Evolution 402 retails for $18,500?
I'm on social security and I work too! Who has more means? You have know way of knowing, nor I.
Don't know about you. But I have to continue to work. SS can not pay the bills unless you have a great retirement plan. Maybe that's the reason I feel the way I do.
Doing both allows for a few luxuries that I could not afford before.
Your opinion carries the weight you've earned, unfortunately you've spent a great deal of that capital on positions that are outrageous or demeaning.
I hope your new PS Audio DAC works better for you.
If I ever do get a PS Audio (the Jr.) It would have to be used. Not new. And, only after reselling the Yggy..
