Hi, I just get my Rag2 I want ask, should I warm up rag before listening and do you guys switch power off when not listening? Thank you!
Schiit Ragnarok Amplifier
- Thread starter Barry S
bagwell359
It should be all warmed up in 20 min. I've got a "1" so I shut it off when done - except when I had it in a 55F basement, then it was on a lot.
OTOH my Gumby likes to be on for days at a time and usually only goes off for nasty electrical storms.
I wouldn't stress over it too much.
Zer0.p0int.Zer0
No it isn't an alps pot and is their own design built into the mother board and not an 'add on' part.
Look at the circuit board pic for confirmation.
https://www.schiit.com/products/ragnarok-1
JJ
Have you ever noticed there is a very brief audio drop out when changing the volume? It happens at each step after the click. I notice it more through headphones than speakers. It’s not really a problem, just messes with my OCD a little.
Anyone else have that issue?
johnjen
Yes there is an audio mute function built into the volume control function.
This further reduces the noise of the circuit as it changes the volume of the signal.
And the mute function is used whenever any of the operating modes of the amp are made (gain, input and output) to make these transitions as 'smooth' as possible.
JJ
JJ
ra990
This is normal. I think it's when it's between two resistors in the relay ladder or something like that. I'm sure someone else can explain better, but it's inherent to the stepped attenuator design. The Violectric V281 had the same behavior with it's stepped attenuator. Small price to pay for perfect channel tracking.Have you ever noticed there is a very brief audio drop out when changing the volume? It happens at each step after the click. I notice it more through headphones than speakers. It’s not really a problem, just messes with my OCD a little.
Yes it is very audible with headphones.
ra990
bagwell359
I can't imagine doing this with many amps, but the Rag 2 runs incredibly cool. You can't see it, but there is a nice gap below the monitor and the amp, so it can breathe.
A lot of amps outside of Class A bias run cool or at least comfortable to the touch. 2 is cooler than 1 for two primary reasons. They set up the chassis to shed heat more efficiently and its only in Class A thru 1 watt, not 4 like the 1.
Zer0.p0int.Zer0
I’m more and more impressed with this amp every day. Currently using it in my basement system with a pair of 50-year old (slightly restored) KLH model sixes. The Rag 2 really makes them sing. The headphone output also seems to be getting better every time I listen to it. One of those amps that’s really hard to turn off.
Edit: I will add though, the remote sucks. I can get it to adjust the volume about half the time and then when it finally kicks in, it overshoots and blows my eardrums out.
bagwell359
6's.... boy its been a long time. Needed at least 60 wpc to get them to play in a medium/large room. Highs sort of fade off around 14kHz. They were grown up Dyna A-25's. Kind of similar to the Lg Advent (but much more pleasing treble than the Advents and AR 3a's), more integrated than the KLH-5.
Besides the blizzard of planar headphones I have on it, I run a high efficiency set (94 db) of 3 way floor standers to high levels and dynamics every now and then too.
Rensek
I've found that the stock batteries wear out quickly. When the batteries get weak the performance of all the schiit remotes really drops. Buy some Duracell or Energizer batteries, they last longer and give improved performance....
Yeah the field of view for that eye is narrow.. I just pretend im playing duck hunt or laser tag. Also, my cheeto dust covered fingers have impacted the remote before. wiping off the transmitter and occasaionaly dusting your gear off helps too.
Ive commented elsewhere before about wishing for RF transmitters, but was informed that the IR was likely chosen for low noise inside the unit.
- Sep 25, 2010
Anyone getting humming / buzzing from their Ragnarok's 2 transformer? Is this normal?
Can it be fixed with a mains conditioner ?
Thanks for any guidance.
Zer0.p0int.Zer0
Yes my Rag2 also has transformer hum and I believe it is normal. For me it is only noticeable when you are very close to the amplifier, not through the speakers. I think I remember reading that the transformer is enclosed in a metal box to reduce noise.
I can hear some tiny tiny buzzing when I very close the amplifier. It’s not bother me, I believe it is normal, my dac is same as well.Anyone getting humming / buzzing from their Ragnarok's 2 transformer? Is this normal?
- Sep 25, 2010
@Zer0.p0int.Zer0 @allenwong - Thanks Guys for confirming there is small buzz/hum and its normal.
My OCD might get the better of me, will keep you posted if I find a way to remove it.
