mRaaghava
- Sep 29, 2016
Anybody tried Modius with SMSL SP200 amp? If so, how will be this combination sound? Sundara is my headphone. Will this combo be harsh or warm?
What cans are you using with your Asgard / Modius stack?
I've spent more time with the Modius and can report that using the XLR outs and a THX AAA 789 the sound is very transparent, punchy, and clean. No signs of distortion, clicking, or artifacts.
I must say the input selector switch on the Modius has got to be the cheapest feeling button I've ever felt on anything. It's loose and sounds so cheaply implemented. I wish it had some spring to it so it didn't feel this way, but time will tell if this is a point of failure.
@Jason Stoddard
I noticed on the Modius I have that after I unplug it for a while and then plug it back in, even if I'm on the Optical Input, I have to cycle the input switch to "wake up" the connection. My PC recognized the optical output, but nothing would come thru to my amp. After I cycled the input selector it works. Might want to keep an eye out for this as it is a little bothersome, nothing major of course, but inconvenient.
Powered externally. My PC does go thru a sleep cycle so perhaps the optical output is not waking up, but it works just fine using my E30 DAC.
