Solude
I'll throw up the other comparisons when the kids are sleeping. Back soon.
The short of it is the Peak is staying and the Mjolnir is up for sale to the next lucky Canuck.
Does the Mjolnir have any turn on/off thump?
@Sol, how does the Mjolnir compare to the Trafomatic?
Look up I didn't listen for or notice any thumping. The power supply is the nice overbuilt type that continues to power the amp after power off for a good 10-20 seconds.
All 4-pin XLR connectors that I have seen have numbers on the pins. Schiit follows the standard convention as follows:
Pin 1 = Left +
Pin 2 = Left -
Pin 3 = Right +
Pin 4 = Right -
Note if you are rewiring a typical 1/4" plug (TRS) and assuming there are four wires in the cable (Sennheiser, Audeze, etc.), the two wires that are attached to the sleeve are the "-".
Are you planning to build your own interconnects for a balanced connection between your DAC and the Mjolnir too?
Nope, I've reterminated my HD 800, LCD-2, HD 650, SRH-1840 with 4-pin XLRs, but I'm using Blue Jeans Cable XLRs between my DAC and amp. It's easy to make the balanced interconnects, but when it comes right down to it, I'm lazy I guess.
And the official A/B is complete. Here we go...
The long of it is a little more involved. As with all my reviews this is in comparison, not global. The Mjolnir is a detail and dynamics monster. No question it will show you things that went unnoticed, clarify others and just flat out give you jaw dropping detail retrieval. In the global sense of the word, its likely neutral as well. But where it falls apart is in separation and staging. The Peak is more natural, if a touch bottom tilted but what it does well is detail, though not at Mjolnir levels, and separation. Things just never blend or become a wall with the Peak. The Mjolnir despite great detail, tended to blend the bass lines into the mid mix. Staging was mostly left to right, with comparatively more 3 blob staging than the Peak.
So in the end it becomes a trade off. The Peak is more natural sounding, trading some detail and clarity for better separation and staging. The Mjolnir has more detail retrieval and likely more neutral as well but can feel top tilted and fatiguing if, like me, you are sensitive to that.
Bring on the statement amp so I can drop my favourite tube in to tilt it back in my favour and have the best of both
Well, I'll be.... I looked at that post for a good five minutes and didn't even see that! Thanks!
