paradoxper
Didn't Jason initially say it would be twice the amount of the balanced offerings and still be either SS or Tube your choice.
Jason-any news on the plating issue--delivery time for the Moljnir?
Jack
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
Is Mjolnir 'idiot proof' with the relay thingie (technical term)? Is that what's described in the "DC servo and relay protection for all outputs'? Forgive me, but I'm really new to the amp side of things. Will the statement amp also have this? I just know myself and I won't be connecting and disconnecting my headphones from my amp. I didn't even know this could be an issue with amps until I got into discussions about the Crack DIY stuff.
As I take it, on the headphone side, the Mjolnir is indeed idiotproof. Good thing
On the opposite side though, it is farther from that than most amps. Connecting a balanced source with the switch in the wrong position will probably end badly, so will connecting two sources at once.
Other than that, you'll have to ask Jason.
Given that the mjolnir has both the 4 pin balanced xlr, and the dual 3 pin for headphones, can anyone mount a case for which is better, or are they identical? I need to purchase new headphone cables anyhow, but which ones?
