Jiexi
- Jun 29, 2016
A little off topic, but is anyone looking to get rid of their Mjolnir 2? I can't seem to find second hand ones being sold.
Schiit had B-stock Mjolnir 2s for $80 off of the regular price a couple months ago (I ordered mine on May 10th). I have no idea how often they release their accumulated B-stocks of particular items. I also ordered my Yggdrasil as a B-stock. I don't know if they were customer returns or there was a blemish on the outer case that's so minor, that it's not even worth noting. I wouldn't hesitate to order B-stock from them, plus you get the full warranty, which you don't get when you buy used.
Not the answer you were looking for, but if you're not in a huge rush, it's worth checking for B-stocks on their website, if you can't find a used one. I'm keeping my Mjolnir 2, but may sell my Valhalla 2.
^ I got a B-stock Yggdrasil. Finished in black, which usually means it was refinished because of cosmetic damage. We have not been able to find where the blemish might have been, and other headfiers' (as well as Pete above) have stated this too over the years...
It depends on 1. sensitivity of headphones, 2. recording volume level, and 3. DAC output level, but 2 o'clock not strange for single ended.
Single ended in Mjolnir 2 said to have only 1/4 power compared to balanced output.
However, I tried balanced and SE with both ETHER and came out just slightly more than 1 hour difference in volume pot setting.
Difference were about the same by PM-3 in single ended and balanced.
With ETHER balanced sourced from Gungnir Multibit balanced, I usually listen in volume pot around 9 to 12 o'clock.
But by K501 single ended, which is the most hard to drive headphones I own (much harder than HD650 or K701), could be cranked up to 3 o'clock in classical orchestral music.
Both in low gain.
i didnt know they do black finish, i wish i requested that before i ordered my stack, it would look so much better in black
You can't order black as it's only done when there's a blemish. We were incredibly lucky. My wife preferred black but it wasn't a deal-breaker. I mentioned this in the order and...Schiit had one available in B stock. It's always worth asking.
Can anyone tell me the total height of a gungnir/Mjolnir2 stack? (from desktop to top of mjolnir, not including tubes)
Heard a first-generation WA5-LE yesterday. It was extremely musical with HD800, but exhibited debilitating transient clipping with HE-6. Mjolnir 2, while not the last word of summit-fi refinement, provided much more power. I can turn it up to ear-splitting levels without it exhibiting any of the hideous distortion that I heard with the WA5-LEv1. I note that the second-generation WA5-LE fixed this problem.
Bottom line, I loved my Mjolnir 2 yesterday, and with my Tidal subscription, today I love it even more. <3
Does this mean you have heard the new WA5-LE and compared it with the Mjolnir 2? If so, which do you recommend to go for (the huge price difference is noted...)
